There could be a few reasons. Try a different power outlet and check the cord and belt. Next there are two safety switches on the Kirby that need to be engaged for the vacuum to start. One is on the mini-emptor to make sure an outer bag is engaged, the second is on the front nozzle to make sure the nozzle or hose is attached. You can see pictures here.
GoodVac.com Technician
www.goodvac.com
1-800-755-6586
SOURCE: Manual and tools kirby g4
The first link is instructions for changing a belt. The second is for the shampooer instructions. If you click on the links below, it will take you to my online guides and if you look there, your other question will be answered. Thanks!!
Marci
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
SOURCE: kirby g4 vaccum
please clarify what you mean?
Do you mean motor bearings or brush roll bearings?
brush roll bearings can be adjusted to lower the brush closer to the carpet when worn.
to do this remove the front brush assembly, there is usually a sticker below the belt hole showing RED = POSITION 1 HIGHEST (ie a new brush roll)
GREEN = POSITION 2 MIDDLE (brush part worn)
BLACK = POSITION 3 LOWEST (brush fully worn)
At each side of this there are 2 clips unlock these and remove the bottom cover.
Release the belt tension by rotating the belt release at the front.
Before removing the brush roll, at each end of the brush roll there is a grey plastic bearing carrier (Square at the ends) MARK this with a pen or marker just so you know the original position, also look closely for the coloured markings as indicated above or numbering 1,2 or 3.
If RED or "1" is showing you need to remove the brush roll by pulling it out and rotate the endcaps to Green or "2" and re-insert the brush roll, If Green or "2" is showing then rotate the endcaps to Black or "3" and re-insert.
If Black or "3" is showing then the brush roll is worn and cannot be adjusted any more, fit a new brush roll and insert with RED or "1" showing.
To re-attach the belt, move the belt to the middle of the roll and rotate the belt knob at the front ensuring the belt engages with the hook on the inside.
SOURCE: Kirby G4 Vacuum/Shampooer
i find the kirby carpet washer is rubbish coz it leaves all the dirty water in your carpet and it goes smelly!
