It tries to close but then opens back up
SOURCE: kvt-715 dvd
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
SOURCE: forgot my password on my kvt 715 help me please
Type 1
Type 2
Type 3
SOURCE: kenwood kvt-715 dvd
if its a kenwood thin you can use any kenwood remot and push 55222277 this shold reset it..
SOURCE: kenwood kvt 715
All of the Compatible Kenwood Units will have Bluetooth Printed on the Face in Small Letters. If yours Does not, Go to Crutchfield.com and they will have the Connectors that you need for this to be done. Please Rate My Response! Thanks!
