The drive belt keeps coming off need digram to makesure its on right
SOURCE: i cant get the drive mower belt on my poulan pro lawn tractor!
The belt you should have bought is part # 140294 and yes, it is longer.
SOURCE: Loss on drive on Poulan Lawn Tractor
Check to make sure the belt is not broken or did not come off the transaxle pulley, you can check by removing battery from under seat and pulling battery box out to examine top of transaxle,Pay close attention to the wire belt guide on the rh side of the transaxle pulley it should be close to the backside of the belt after it is reinstalled.If you recently may have removed the rear tire make sure the square key on the axle didn't drop out.Is the tractor a hydrostat drive? If so make sure brake is not stuck on,if it was it would make a grinding noise.
SOURCE: belt is slipping off pulley
your should have a tension spring on the idler pulley. that maintains the tension on the drive belt. check to make sure you have the right belt and that is not worn or stretched out. also check to make sure your variable drive assay is working
SOURCE: I am trying to replace my deck drive belt and do
you may have missed it but the diagram is on the deck , look closely you should see it, anyway it should look like an upside down t if you were siting and looking at it from the drivers position. you should have to remove only one pin to get the belt on and it would be on the right side of the deck
