This is the result of a bad flash. There is nothing that you can do unless you reflash the bios to another version. In some cases you have to order a new bios
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive.
Try this:
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected properly. Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
- Floppy drive - CD drive - Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Boot from either your emergency repair disk, your bootable Windows CD, or your bootable restore CD. Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
If the above fails:
Verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
If all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
When you start your laptop, press Del or F2 to enter BIOS Setup program. There adjust your BIOS Settings to detect your new hard disk. When detected, save the BIOS settings and exit BIOS Setup.
AMI (American Megatrends International) BIOS Beep Codes. AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure. BEEP CODE MEANING POSSIBLE CAUSE 1 Beep (No video) Memory refresh failure Bad memory 2 Beeps Memory parity error Bad memory 3 Beeps Base 64K mem failure Bad memory 4 Beeps Timer not operational Bad motherboard 5 Beeps Processor error Bad processor 6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard 7 Beeps Processor exception Bad processor 8 Beeps Video memory error Bad video card or memory 9 Beeps ROM checksum error Bad BIOS 10 Beeps CMOS checksum error Bad motherboard 11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running. BEEP CODE MEANING POSSIBLE CAUSE 1 Long, 2 Short Video adapter failure Bad video adapter Repeating (Endless loop) Memory error Bad memory or bad connection 1 Long, 3 Short Video adapter failure Bad video adapter or memory High freq. beeps (while running) CPU is overheating CPU fan failure Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps. Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
BEEP CODE MEANING POSSIBLE CAUSE 1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard 1 - 1 - 3 CMOS read/write failure Bad motherboard 1 - 1 - 4 BIOS ROM failure Bad BIOS chip 1 - 2 - 1 Timer failure Bad motherboard 1 - 2 - 2 DMA failure Bad motherboard 1 - 2 - 3 DMA failure Bad motherboard 1 - 3 - 1 Memory refresh failure Bad memory 1 - 3 - 2 64K memory failure Bad memory 1 - 3 - 3 64K memory failure Bad memory 1 - 3 - 4 64K memory failure Bad memory 1 - 4 - 1 Address line failure Bad memory 1 - 4 - 2 Parity error Bad memory 1 - 4 - 3 Timer failure Bad motherboard 1 - 4 - 4 NMI port failure Bad motherboard 2 - 1 - 1 64K memory failure Bad memory 2 - 1 - 2 64K memory failure Bad memory 2 - 1 - 3 64K memory failure Bad memory 2 - 1 - 4 64K memory failure Bad memory 2 - 2 - 1 64K memory failure Bad memory 2 - 2 - 2 64K memory failure Bad memory 2 - 2 - 3 64K memory failure Bad memory 2 - 2 - 4 64K memory failure Bad memory 2 - 3 - 1 64K memory failure Bad memory 2 - 3 - 2 64K memory failure Bad memory 2 - 3 - 3 64K memory failure Bad memory 2 - 3 - 4 64K memory failure Bad memory 2 - 4 - 1 64K memory failure Bad memory 2 - 4 - 2 64K memory failure Bad memory 2 - 4 - 4 64K memory failure Bad memory 2 - 4 - 4 64K memory failure Bad memory 3 - 1 - 1 Slave DMA failure Bad motherboard 3 - 1 - 2 Master DMA failure Bad motherboard 3 - 1 - 3 Interrupt controller failure Bad motherboard 3 - 1 -4 Slave IC failure Bad motherboard 3 - 2 -2 Interrupt Controller failure Bad motherboard 3 - 2 - 3 <RESERVED> 3 - 2 - 4 Keyboard control failure Bad motherboard 3 - 3 - 1 CMOS batter failure Bad CMOS battery 3 - 3 - 2 CMOS configuration error Incorrect setting 3 - 3 - 3 <RESERVED> 3 - 3 - 4 Video memory failure Bad video card or memory 3 - 4 - 1 Video init failure Bad video card or memory 4 - 2 - 1 Timer failure Bad motherboard 4 - 2 - 2 CMOS shutdown failure Bad motherboard 4 - 2 - 3 Gate A20 failure Bad motherboard 4 - 2 - 4 Unexpected interrupt Bad processor 4 - 3 - 1 RAM test failure Bad memory 4 - 3 - 3 Timer failure Bad motherboard 4 - 3 - 4 RTC failure Bad motherboard 4 - 4 - 1 Serial port failure Bad motherboard 4 - 4 - 2 Parallel port failure Bad motherboard 4 - 4 - 3 Coprocessor failure Bad motherboard or CPU. 9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Is the mother board working? If so, why are you flashing the bios? If the bios is bad and can not be flashed, you may be able to buy a pre-flashed chip if it uses a removable flash chip. Try this site but you can find others on the Internet.
There is no overclocking settings for this motherboard, the CPU speeds and core settings are automatically determined. You may be able to find a modified bios somewhere, but i would strongly suggest this not be done. A bad bios, or bad flash can essentially turn the motherboard into an expensive paperweight.
BIOS updated successfully. 2L-1S-1L F1h The BIOS file size is not equal to the BIOS ROM size; wrong BIOS file. 1L-1S F1h The BIOS file can't be read; it is defective. 1L-2S F2h The model ID is mismatched; wrong BIOS file. 3S F3h The BIOS ROM has failed to be erased. Try to flash again. 2L-1S E1h The BIOS ROM has failed to be programmed. Try to flash again. 2L-2S E2h No diskette, or cannot locate the BIOS file. Try to use a new formatted diskette and copy the BIOS file again. 2S D1h
