GPS Logo
A
Anonymous Posted on Jun 05, 2014
Suggest measures to protect and developing the fishing industry in pakistan
6answers
What effective measures did chhattisgarh government has taken in Development of state tourism?
Shri Ajay Chandrakar strongly advocates that the development of tourism industry in Chhattisgarh will help in creating employment opportunities for youth of the State and this will save them from influence of Naxals, a movement that has been a major stumbling block in development and progress of the state for more than 2 decades.
He has emphasized on the state government`s plan of expanding world class tourism facilities in naxal affected Bastar and the impoverished of all districts in Chhattisgarh, Sarguja. This would in future enable the local youths by more employment opportunities and infrastructural development in the respective districts.
Who is Ajay Chandrakar
Froze wont turn off
if you mean the screen freeze wont turn off , this is normal the display will only update if a reading greater than .10 has been measured between samples , i had same problem when measuring diff fish tanks with this probe , ive had to develop a dilution process to get readings for tanks instead
1helpful
3answers
Suggest the measures to protect and develop the fishing industry in pakistan?
The best gauge to protect the ocean is to stop the industrial waste right away. And then taken measures to ensure to part of food. The industry can be grown by exporting the fish to different regions and all over the world.
I HOPE THAT THIS ANSWER CAN HELP U!!!!
How to kil hydra
Things You'll Need:
  • Aquarium vacuum
  • Additional freshwater
  • Fish food
  • Commercial medication (optional)
  • Step 1:Vacuum the aquarium. Sweep the bottom of the tank with the vacuum to remove the hydra and a majority of their food sources. Use the aquarium vacuum as needed to keep the freshwater aquarium clean. This will prevent more hydra from appearing in your aquarium.
  • Step 2:Replace any lost water. Vacuuming the aquarium will pull out a fair amount of water. Replenish the aquarium with additional freshwater. Northern State University suggests using freshly collected pond water or rain water.
  • Step 3:Reduce the amount of food you feed the fish in the tank. Temporarily decreasing the amount of food will result in larger fish feeding on the hydra and eliminating a source of food for the hydra. If food is unavailable, hydra reproduction will cease and they will eventually shrink then die.
  • Step 4:Repeat these steps as necessary. Continue the three-step process until all signs of hydra are gone. Negligence in cleaning the tank or feeding the fish ample amounts will allow the hydra to feed as well, and thus rapidly reproduce. Continuing the steps is also a maintenance measure that will prevent additional hydra from developing in your freshwater aquarium.
Tips & Warnings
  • Aquarium-supply stores sell various medications that reportedly kill hydra.
  • The steps you take to kill freshwater hydra could also kill small fish in your tank. Prepare to lose some small freshwater fish fry in the process.
3helpful
2answers
Wat r the safer construction practices against tsunami
Mitigation measures for risks associated with geohazards can broadly be classified in six categories: (1) land use plans, (2) enforcement of building codes and good construction practice, (3) early warning systems, (4) construction of physical protection barriers, (5) network of escape routes and "safe" places and (6) community preparedness and awareness building.
Early warning systems and construction of physical protection barriers have been singled out as specific tasks in the proposed ICG research. Together with the other four categories, they form the backdrop for a mitigation strategy.
The results of hazard and risk mapping and analyses will be used to formulate mitigation strategies to assist decision-making on the need and cost-benefit of hazard mitigation works. Based on such a strategy, protection measures can be developed and their cost-effectiveness and environmental soundness compared.
A mitigation strategy would involve: (1) identification of possible disaster triggering scenarios, and the associated hazard level; (2) analysis of possible consequences for the different scenarios; (3) assessment of possible measures to reduce and/or eliminate the potential consequences of the danger; (4) recommendation of specific remedial measure and if relevant reconstruction and rehabilitation plans; and (5) transfer of knowledge and communication with authorities and society. The strategy developed by ICG and NGI for the tsunami-affected areas of Thailand after the 26th December 2004 Indian Ocean tsunami provides a good example of what can be done.
Any mitigation strategy needs to be adapted for different natural hazards and different parts of the world. Especially for developing countries, it is vital to establish and promote proper land-use planning and construction practices to regulate human activities that increase risk to earthquakes, landslides or tsunamis and to prevent settlement of communities in high-risk areas.
Physical protection measures include, but are not limited to, integrated land use planning, drainage, erosion protection, vegetation and ground improvement techniques, barriers (earth ramparts, artificial elevated land, anchoring systems, retaining structures), and offshore or onshore walls to reduce the energy or the loads induced by geohazards (e.g. landslide, rock slide, tsunami, floods).
Buildings need to be designed (and placed in locations) to withstand the impact forces of geohazards and to provide safe dwellings for people. Land can also be elevated to ensure that buildings are above a critical height, for example to protect against tsunami danger.
Top National Geographic GPS Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a National Geographic GPS Expert? Answer questions, earn points and help others
