What you refer to as the "circle" is most likely the low voltage battery symbol and flashing means to change the batteries. The wrench means fault which just goes along with changing the batteries.
Put on the charger for 1-2 hours then unplug it and use it.
You should be able to see the battery level. This is telling you that it take charge or not.
-If it still very low or same as before charge then the battery might be defect. Replace new battery.
That symbol means that the tablet battery is plugged in and is supposed to be receiving charging voltage. If the battery is bad, it may not charge but the tablet will still work with the charger plugged in.
does the phone charge when connected to the computer? The lightning icon means it is connected to power and is charging. Try another charger, it seems like your charger is the problem, not the phone.
lighting symbol? Im assuming thats a iPhone or iPod Touch. this means your iPhone is dead keep it plugged in for a day or two if it still fails to turn on try plugging it in to charge somewhere else like a wall charger.
