Question about Casio FX-115ES Scientific Calculator
How do i get answers as decimals in casio fx 115 es plus
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 19 Answers
If you have any ideas then share with the all but if you also want to a easy and interesting game for the all then come here http://commandpromptwindows10.com and read this article because its so easy and interesting.
Posted on Oct 30, 2018
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
    An expert that gotĀ 20 achievements.
  • Casio Master
  • 102,366 Answers
To convert a single result to decimal, press the S<=>D button just above the DEL button. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Posted on Jun 06, 2014
4 Suggested Answers
SOURCE:
SOURCE: When I divide, it turns the answer into a fraction. How do I get back so the answer will be a decimal?
Press the S<>D key, (located right above "DEL"). This will shift the answer from fraction to decimal. This sounds like a pain but having both functions available can be a big plus.
Posted on May 20, 2009
  • 8081 Answers
SOURCE: Casio FX-115 ES: SIN,COS,TAN (answer isnt correct)
It may be due to the angle unit used. You can have angles in degrees, in radians, and in grads. You should set the default angle unit to waht you problem calls for.
To set degree as default SHIFT MODE 3
To set radians as default SHIFT MODE 4
To set grads as default SHIFT MODE 5
The values of angles calculated by the inverse trigonometric functions are in the default unit that is set . This may be the source of the wrong answers that you get.
Hope it helps.
Posted on Sep 17, 2009
Testimonial: "thanks alot!! "
  • 8081 Answers
SOURCE: Casio fx-115 es i get all my answers in decimal form but i want them in radical form, how?
Set the Input/Output mode to MathIO.
To do so, press [SHIFT][MODE] to open (SetUp), then select [1:MathIO].
When in MathIO you can toggle between the display formats by pressing the [S<>D] key.
Posted on Mar 29, 2012
Is it possible to solve eqn in this 82ms calculator
Sorry, It is not possible to solve equations on the Casio FX-82 ms. Try the Casio FX-115 ES/ FX-115 ES Plus, FX-991ES/ FX-881 ES Plus C.
Oct 29, 2013 | Casio FX82MS Scientific Calculator
Which model of casio csn do integration in limits
The Casios FX-115 ES , FX-115 ES PLus, FX-991 ES, FX-991 ES Plus C can perfom numerical differentiation at a point, and numerical integration between two given limits.
Aug 12, 2013 | Casio FX991ES Scientific Calculator
My fx-115 es wont allow any decimals, and the word 'dec' appears on the screen at all times
Try reseting it by pressing "shift" , "9" , and "3" in that order after you turn it on. It might fix it mine did the same thing and it fixed it.
Apr 23, 2012 | Casio FX-115 Solar 236 Function Scientific...
Mar 29, 2012 | Casio FX-115ES Scientific Calculator
The answer is displayed in scientific notation and I want to change it back to normal.
Press the shift key, then the mode key, then find a menu item called fix. It will display 0~9. The number you choose is the number of decimal places the calculator will display in your answers. On my casio (fx-115 ES) the order to do it is shift->mode->6 then the # of decimal places i want it to go out to.
Nov 02, 2010 | Casio fx-300ES Calculator
How do i get my casio fx-115 es calculator to show answers in decimal form?
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Sep 21, 2010 | Casio FX-115ES Scientific Calculator
Can I convert Degrees, Minutes, Seconds to Decimal Degrees on my casio fx-115 ES?
Press the SD key (just above DEL). You may have to press it twice if the first press produces a fraction.
Sep 19, 2010 | Casio FX-115ES Scientific Calculator
How do I have my casio 115 es give answers as decimals instead of fractions?
To convert a single value to/from fractions, press the S<>D key.
To get all answers in decimal form, press SHIFT [MODE] 2 to select LineIO mode.
Aug 16, 2010 | Casio FX-115ES Scientific Calculator
When I divide, it turns the answer into a fraction. How do I get back so the answer will be a decimal? With a Casio fx-115 ES
May 20, 2009 | Casio FX-115ES Scientific Calculator
Casio FX-115ES Scientific Calculator Logo
2,011 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
