Question about NewAir Heating & Cooling
I bought a Newair acp-1000h portable air conditioner from a yard sale. Problem is I now find out it has a remote control, exhaust hose, connector pieces....I only bought the main unit with no accessories. This model is discontinued. Where can I purchase everything except the main air conditioner?
6ya staff
SOURCE:
Joe Hogan
  • 10865 Answers
SOURCE: Exhaust Hose DeLonghi PAC-210U replacement
you can contact the company directly at
Contact Center
1-877-882-8604 Monday – Friday
8am – 8pm EST
good luck with this.
Posted on Feb 14, 2009
Anonymous
  • 134 Answers
Hi
You need to go here
://www.delonghi.co.uk/accessories.php
shizznat
  • 24 Answers
SOURCE: exhaust hose
i could not find that model number on the haier website www.haieramerica.com you can get the manuals and parts list there. you dont need the haier hose however lowes and home depot sell what im guessing is three or four inch hose that you can use say a dryer vent flex hose or alumaflex hose to connect this unit. unless you are going for the looks.
Posted on May 31, 2009
Norman Al-Anbar
  • 630 Answers
SOURCE: The Newair acp 1400h puts out a lot of heat and
The longer hose will increase the heat in the room and that is why they recommend the short hose…addition to that it may overheat…if you are going to extend the hose you must use one as the dryer hose that insulated and fire proof…let me know if that help
Please do not forget to rate my service for the site to continue helping everyone and improve on it.
Posted on Sep 17, 2009
caroldon
  • 17130 Answers
SOURCE: My NewAir ACP-1000E Portable Air Conditioner says
Check the float thaat is the sensor to indicate the water level to the micro controller. The wires are cut or the float is deffective .
Check and replace.Credit if helpful with this tip.
Posted on Aug 24, 2010
Need to locate a operations manual. Moved into a house that has unit but no instructions
Could this be what you're looking for: http://www.newair.com/manuals/newair-ac-14000h.pdf
Jan 14, 2013 | NewAir ACP-1400H Portable Air Conditioner
AC is New Air model ACP 1000 E The unit fills up every 5 hours. Is there a way to run the AC without the dehumidifier? The setting is currently on the snowflake.
No, a byproduct of cooling the air is condensation....or dehumidification... so in short.. if you want to cool the air you will also dehumidify it...
heatman101
Jun 15, 2011 | NewAir ACP-1000E Portable Air Conditioner
My NewAir ACP-1400/H air conditioner freezes up. I have cleaned the filter and check the air flow. Everything seems good, but it still freezes up.
Its sounds like a refrigerant leak from the factory if you just got it. Check your warranty and call the manufacturer for repairs. Unfortunately there is no simple fix.
May 17, 2011 | NewAir ACP-1400E Portable Air Conditioner
The air conditioner is blowing hot air, there is no water to drain
if it is also blowing cold air out of the other vents you need to vent the hot air its blowing outside
Sep 30, 2010 | NewAir ACP-1000E Portable Air Conditioner
My NewAir ACP-1000E Portable Air Conditioner says the water tank is full yet it is empty. Any ideas?
Aug 24, 2010 | Heating & Cooling
Loud rattle in a new newair ac-1000e bt
Buy some 1/2 thick rubber pads and put it under the unit, I am assuming it is on rollers or has feet. This should eliminate some of the problem
Jul 14, 2010 | NewAir ACP-1000E Portable Air Conditioner
The Newair acp 1400h puts out a lot of heat and the manual says not to extend the exhaust hose. Is there any way to extend the hose so that I can exhaust where I want to?
Sep 17, 2009 | NewAir ACP-1400H Portable Air Conditioner
Not blowing cool air
Likely needs freon has leak needs repair local hvac contractor can help. T
Jun 16, 2009 | NewAir ACP-1600H Portable Air Conditioner
Heating & Cooling Logo
Top NewAir Heating & Cooling Experts
Donni Steen
Lollo Pop
Norman Al-Anbar
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
