Canon MultiPASS MP390 All-In-One InkJet Printer Logo
A
Anonymous Posted on Jun 05, 2014
How to clean canon mx892 sheet feeder scan head
Roger Walters
Level 2:
New Friend:
  • Expert 147 Answers
  • Posted on Jun 05, 2014
Roger Walters
Expert
Level 2:
New Friend:
Answers
147
Questions
0
Helped
41079
Points
370
How to clean the sheet feeder in a Samsung multi function M2880FW
Open the sheet feeder top door and you will see a narrow glass strip. Somewhere on it, you will see something that is causing the streaks. Clean with an alcohol wipe and polish.
https://www.google.com/search?q=Samsung+multi+function+M2880FW+clean+sheet+feeder
Canon MX892 printhead bad?
hi
find link for how to clean the printer head
https://www.youtube.com/watch?v=ZGElrMuU8m4
Having a problem scanning; say ADF
Check manual or tech support. Maybe youtube has video. check your automatic document feeder for blockage.
I have changed all ink cartridges on my canon pixma ip4200 printer and it now doesn't work, the green and amber lights flash for 11 times and the cartridge carrier doesn't move. Please can someone advice...
From Canon Help Files.
Automatic Print Head alignment failed
Possible causes are as follows:
6128_image_6.gif A4 or Letter-sized paper is not loaded on the Auto Sheet Feeder.
Press the RESUME/CANCEL button on the printer to clear the error, then load one sheet of A4 or Letter-sized paper in the Auto Sheet Feeder.
Automatic print head alignment cannot be performed using paper from the Cassette. For automatic print head alignment, always load paper in the Auto Sheet Feeder.
6128_image_6.gif Print Head nozzles are clogged.
Press the RESUME/CANCEL button on the printer to clear the error, and then print out the nozzle check pattern to examine the print head condition.
For information on how to print a nozzle check pattern, see "Printing the Nozzle Check Pattern."
6128_image_6.gif The Paper Output Slot has been exposed to a strong light source preventing correct Print Head alignment.
Press the RESUME/CANCEL button to clear the error and move the printer to a darker location.
After carrying out the above measures, if the problem continues after aligning the Print Head again, press the RESUME/CANCEL button to clear the error, and then perform manual print head alignment. For details on manual print head alignment, see "Manual Print Head Alignment."
Canon MX892 - when I scan, an error code 2156 comes up saying scanner is turned off or usb cable unplugged
Hi.
Try to check up first scanner power cable and network wireless router.
If it are running running good. your scanner have defective parts. like
IC chipset.
Second option : try to general cleaning your Canon PIXMA MX892 Network-Ready Wireless All-In-One Printer. using vacuum.
Hope can help you.
3helpful
How to print address on envelope on canon mx892
Printing envelopes on Canon MX892: Remove paper from rear tray. Adjust gray width handlers to the size of your envelope. Insert a blank envelope in the rear feeder, with flap oriented on the back left side.
2answers
My mp730 does not scan since i moved to a new computer under windows 7. I have downloaded the dedicated driver from Canon for the Mp730 with windows 7. Everything else wors properly, printing from word,...
Did you download and install the MP Toolbox (shown under the Software heading) from this link? This is the software program that allows the computer to use the scanner.
3helpful
2answers
Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Not scanning full page
You omitted some details which might help diagnose the problem. For example, are you using the document feeder or the flatbed? Anyway, I'll take a guess here.
Check your paper size setting and make sure it matches the sheet you are scanning. (Letter, A4, Legal, etc.)
If this is not it, then try scanning from both flatbed and feeder and see if results vary. Note that when you use the feeder, scanning is done in a smaller window to the left of the flatbed, so make sure that is clean.
Black Line when using sheet feeder
Open the cover over the scanning area and check the narrow strip of glass to the left of the platen glass. See if there is any foreign material there (dirt, whiteout, etc) and clean it gently with a damp cloth. You may find a piece of clear plastic covering that area. It's there to keep the glass from getting scratched. If the plastic is heavily scratched at that point, it can cause the line you're seeing. Removing the plastic will clean up the scans.
old marine
old marine
ZJ Limited
ZJ Limited
