Brother PC-420 Logo
S
Shadows mom Posted on Jun 05, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The balance wheel is stiff and tight and the needle makes a vibrating sound and has difficulty coming up, then the machine freezes for statey mode
What should I do?
Chris Wetmore
Level 2:
New Friend:
  • Expert 190 Answers
  • Posted on Jan 28, 2015
Chris Wetmore
Expert
Level 2:
New Friend:
Answers
190
Questions
0
Helped
56264
Points
335
This sounds like a bushing is seized or thread wrapped on the machine somewhere.
2 Related Answers
Debbi's Sewing Machine Repair
  • 7365 Answers
  • Posted on Mar 27, 2012
SOURCE: Brother SE400 Hand wheel is very tight and the needle will not go down
if the machine is brand new then it needs to go back & get another one
Anonymous
  • Posted on Jul 21, 2013
SOURCE: Brother ES 2020 Balance Wheel Stiff
Good morning: I'm having this problem too... Just a few months ago I had the bobbin shaft thing replaced as it was jammed. I am not an expert but its happening again.
I have an older Bernina 910 that sews beautifully. However, I have not been able to move the f Ed dogs knob to lower the feed dogs. Any suggestions?
Yep. These older machines are great but they do love to be treated regularly to cleaning and oiling. Feed dogs are often one of the first to fail due to old oil. Then the stitch selectors will stop working, the handwheel may get stiff, and the needlebar will freeze.
Wheel on right side that controls the needle up and down is very tight...
2answers
In sewing mode the motor turns but needle does not move. I have checked bobbin & upper thread - any help?
1. Try to turn the hand wheel. Does the needle move?
2. Make sure the center wheel on the hand crank is tight.
Try the hand wheel now. If you still don't have luck try this.
3. Loosen the center wheel on the hand wheel. There is a small screw on the center wheel on the front or side. Loosen it until it almost comes out.
4. Now tighten the center wheel. (clockwise) Does the needle move if you move the hand wheel? If it does you can tighten the small screw.
5. If this doesn't do the job you will have to take the cover to the motor off. The motor has a bolt to loosen. As you loosen the bolt you can move the motor until it tightens the belt and makes it aligned as well. Run the motor slowly with the foot pedal and adjust the motor until it operates at it's highest speed. Now tighten. Replace all covers.
6. The belt is sometimes in need of replacing but not usual. You will know when you take the panel off.
2answers
How to fix needle on a machine
Turn the hand-wheel counterclockwise until the needle is at the highest point. Lower the guide or presser foot. This will give the maximum room possible for working with the needle.
Turn the needle clamp screw counterclockwise until the needle comes loose. This screw is located on the side of the small
box, known as the needle clamp, that holds the needle in place.
Remove the old needle by pulling it straight down and then angling it outward. Place a new needle into the holding slot or needle clamp.
Tighten the new needle into place by turning the clamp screw clockwise until tight. Do not over-tighten the needle.
Here's a tip
Use a needle that is appropriate for the type of fabric you are sewing. Using the wrong needle may result in breakage and increase the number of needles to be changed
Over-tightening a needle can cause it to be crooked and break. Turn the clamp screw only until the needle feels stiff in place.
here's a link for a manual for the machine
http://www.sewingpartsonline.com/instruction-manual-euro-pro-9110.aspx
Fixing a new needle on a sewing machine
Here's a tip
2answers
did you change the needle?
sewingmachineshop.co.uk
sewingworld.co.uk
.uksewing.com
The hand wheel keeps falling off and now when i try the sew nothing happens, the needle does not move. all i hear is the sound ofthe motor but nothing happens
If the balance wheel is coming off which it should not do because it is held on by the belt then you have not tightened the stop motion in the middle of the balance wheel, make sure you have not lost the little screw in the middle if the balance wheel.
Handwheel on Sewing machine no longer moves needle.
Actually you should have a "set screw" in the hand wheel. The set screw is usally locked down tight to keep the hand wheel from spinning freely. I f you can run the machine slowly and hold the hand wheel in one place but the machine continues running, then you do need to replace the "set screw". If you replace it you will find that you can offset some of the machines vibration by where you lock the wheel down. Trial and error is the only way to achive this adjustment, kind of like balancing the tires on your car.
2answers
Needle won't grab bobbin thread
Check the position of the needle. Some machines have to have the needle in a certain way or they won't pick up the thread from the bobbin. Make sure the screw on the bobbin is tight but not to tight you may have to adjust it a few times to get it where it needs to be. Also make sure the bobbin is wound tight
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
