Question about Konica Minolta Bizhub Press C6000 Copier
Konica bizhub press c6000 AA errors - Konica Minolta Bizhub Press C6000 Copier
  • Konica Minolta Master
  • 6,850 Answers
What is the error code C-XXXX or SC-XXXX or Jxx-xx what was it doing when it happened?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Nov 17, 2015
SOURCE:
herminio_hal
  • 210 Answers
SOURCE: How to setup scan to pc on Konica minolta bizhub 350 Error ED09C7
Your configuration sharing SMB folder is incorrect. Create desktop folder rename all upper case SMB right click on the folder and click sharing and set full control to everyone. Go to web brouser type in the ip address of the printer log on to administrator password 8 zeros or 12345678 and change the setting.
Posted on Jul 09, 2009
  • 6 Answers
SOURCE: how to fix error c0f32
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
Posted on Apr 09, 2010
Bizhubman
  • 108 Answers
SOURCE: how to clear error code c 3421 on konica bizhub
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
Posted on May 19, 2010
xeerie
  • 347 Answers
SOURCE: REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA
to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
wish you best of luck............
Posted on Jun 17, 2010
xeerie
  • 347 Answers
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
Posted on Jun 19, 2010
Error j3201 konica c 6000
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 16, 2016 | Konica Minolta Bizhub Press C6000 Copier
Por que impressora konica minolta bizhub c6000 apresenta error 2703
Check the Cyan Charge Corona housing. Remove it and reseat it. IF not that check the HV board. and or connection at the back of the drum and transfer middle assy.
Oct 16, 2014 | Konica Minolta Bizhub Press C6000 Copier
Bizhub pro c6000
Did you made all the steps from the service manual when you changed the drums and developers?
Aug 28, 2014 | Konica Minolta Bizhub Press C6000 Copier
Konica minolta error code c-4502
Main body: Writing correction drive abnormality
Cause> The tilt correction home sensor /M (PS71) turns OFF while the tilt correction motor /M (M75) in the writing unit is ON.
Estimated abnormal parts> • Printer control board (PRCB) • Writing unit
Jul 18, 2014 | Konica Minolta Bizhub Press C6000 Copier
Konica minolta bizhub 7000 controller doesn't turn on
Turning the Power On or Off - Konica Minolta Online Manuals
manuals.konicaminolta.eu/bizhub-C554-C454-C364.../id10-0061.html
bizhub C554 C454 C364 C284 C224 ... The Main Power Switch of the machine and thePower key on the Control Panel. No. Name, Description. 1. Main Power Switch. Press this switch when turning on or off the main power of this machine or ...
[PDF]C7000/C7000P/C6000/C70hc/ C6000L
myworks.sindoh.com/upload2/.../d37800822888835787371.pdf
KONICA MINOLTA Confidential. 2. C-2721, Intermediate .... v) Execute Printercontroller calibration for every output profile. (Standard ..... Start CWS5 and login to a Fiery controller. ii) Click [Calibrate] ...... If FD skew doesn't remain,. FD skew ......*A1DURX01: For bizhub PRESS C7000/C6000 and bizhub PRO C6501. 2.
Feb 15, 2014 | Konica Minolta Konica Kit For Bizhub Press...
Code d'erreur C3505
Fusing error have tech look at and reset
Jan 24, 2014 | Konica Minolta Bizhub Press C6000 Copier
Error code c-DOE1
Hard drive failure or not connected
Jan 14, 2014 | Konica Minolta Konica Kit For Bizhub Press...
C2231 error code
check the yellow drum unit
Dec 30, 2013 | Konica Minolta Konica Kit For Bizhub Press...
Error code c2801
Maximum density correction problem.Clean the AIDC sensor located under OPC drum.
Mar 19, 2013 | Konica Minolta Konica Kit For Bizhub Press...
Konica Minolta Bizhub Press C6000 Copier Logo
327 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
