Possible causes
- Faulty Front Heated Oxygen Sensor Bank 1
- Front Heated Oxygen Sensor Bank 1 harness is open or shorted
- Front Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks alt="Help with Possible causes"> What does this mean? Tech notes
Replacing the Front Heated Oxygen Sensor Bank 1 usually takes care of the problem
Do you mean Check 34? Fault 34? Either of these indicates a problem with zone 34, which the location should be displayed by your keypad, such as Kitchen Glass, or something of that nature.
system trouble can mean that you might have a faulty expander somewhere. an expander is used to extend the zones on your current system. if not you might have a faulty pacife connected to the system go around all the pacifes and check if the red light comes on. if not replace it.
Beach combing is
basically metal detecting on the beach. Most metal detectors on the beach are
looking for jewelry and coins and in the busy summer seasons, probably can find
quite a bit. This is the most popular kind of metal detecting.
To Activate Sabbath Mode: To use the Warm Zone and/or Warm Drawer during Sabbath Mode, press the WARM ZONE and /or WARM DRAWER keypad before activating the Sabbath Mode. 1. Press BAKE. 2. Press the "+" or "-" key to set a temperature other than 350F (177C). 3. Press START. For timed cooking in Sabbath Mode, press COOK TIME, then the "+" or "-" keys to set the desired cook time. 4. Press TIMER SET/OFF for 5 seconds. "SAb" will appear in the display. To Adjust Temperature (when Sabbath Mode is running): 1. Press the "+" or "-" keypad. Each press of a keypad will increase or decrease the temperature by 25F (14C). No temperature will appear in the display. 2. Press START. To Deactivate Sabbath Mode: Press and hold TIMER SET/OFF for 5 seconds to return to regular baking or press CANCEL/OFF to turn off the range
Not Ready means one or more of your zones is faulted. Pressing the * key on the keypad will display the zone or zones that are faulted. A faulted zone can be a door or window open, a motion detector "seeing" movement, and so on. It will also display a description of the zone. Chime means the chime feature on the keypad has been enabled. Any perimeter or entry/exit zone that faults will cause the keypad to ding three times. This can be turned off by entering your 4 digit code and pressing the 9 key. Doing so again will turn it back on. The link below is for the user manual for an Ademco Vista 20P panel.
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds. SOLUTION Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
