Nextbook Premium 8 Se Android Logo
A
Anonymous Posted on Jun 05, 2014
How do I move memory in my Nextbook 8se premium around to better manage it?
My internal memory is nearly full and my SD Card is nearly empty. How do I move some internal memory storage to my SD Card memory?
Lawrence McCaskill
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jun 10, 2014
Lawrence McCaskill
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
Helped
2769
Points
13
As far as i know this meathod usually works with apps. First you go to settings, second you go to storage, third you go to something like apps, fourth you select an app, fifth you select move to SD card or move to internal memory depending on where you have your data saved. I hope this helps anyone with this problem, im no expert but i will try my best to help
1 Related Answer
TechyDrood
Justin
  • 2072 Answers
  • Posted on Dec 04, 2012
SOURCE: my nextbook 8se keep freezing up. I've only had it for a couple of days and I'm already getting ready to take it back! Any suggestions to why its doing this?
I don't know if this is available on that model. Give it a try. Press and hold the power button until you get the menu with the option to power it off. Press and hold your finger on the option to power it off for a few seconds. Hopefully you get an option to reboot the tablet into safe mode. This mode will disable all third party apps on the tablet. See if it freezes up. If it doesn't one of the apps is causing it to hang. This will at least tell you if the tablet itself is bad or if it is a problem with an app.
I have a16gig external sd card still unable to down load games says insufficant storage space
Hi, I don't understand much, can you be specific, you can try to redirect instalations from device internal memory to sd card
Can't download games error window says not enough storage. Bought 16 mg memory card not working
Probably you get the error because, by default, all downloads go to the internal storage, not the memory card. Make some room on your device by moving pictures, videos, songs to the memory card. You can also move some applications to the memory card using the Application Manager feature of any Android device.
1helpful
How do Move apps to external sd card?
Download and install ES file explorer. When run, you'll see the main and added memory. Find the app you want to move, hard press and hold it, and drag to new place.
How do i get my tablet to read my micro sd card?
Check to be sure the particular SD card is compatible.
How to set memory card as default memory storage
Download Titanium back up. it has all you need you can move all the apps to sd card including built in apps (the ones that can not be unistalled)
Caution: your phone has to be rooted juts google how it can be done in case you are not rooted yet. and be carefull while moving apps some apps can cause damage to your phone if moved to sd card. just move the downloaded ones and some few like photo viewer, galary, music player and the like
I added a 16GB SD card to my tablet because it was low on space. Transferred everything to SD card that could be transferred but now updates needed for games will not download stating lack of space.
Move some of the items from internal memory to you we card. I had an issue moving an ad card from one device to another and had to reformat the ad card in the new device.
I cant download any apps says insufficient storage but have an sd card that's empty
You can try moving some of the apps to the SD card. If an app cannot be moved, you will get a warning message. Also, if you have any videos, songs or photos on the tablet move them from the internal storage to the SD card.
Apps do not move to external SD
Install App2Sd(from Google playstore) and then try to move the app after restarting your phone
hope that will work
2answers
On nextbook 8se
http://www.androidpit.com/process-com-google-process-gapps-has-stopped-fix
Top Nextbook Tablets & eReaders Experts
NOEL
NOEL
john h
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
