Change tyre less than a year. Not evenly wear and tear on the front. More wear in the inner side
SOURCE: Saturn SL1, growling and vibration coming from right front wheel,
Might be a hub bearing. Those make a growling noise when they are bad. When it is on jack stands you should be able to put your hands on the top of the tire and the bottom of the tire and move it back and forth. and the same with putting your hands on the right and left side of the tire. if you can and it moves back and forth then the bearing is back. but becarefull not to get the movement confused with a bad ball joint or tire rod. which could also be your problem but they dont make a growling noise
SOURCE: 2004 mitsubishi outander rear wheels tilting - extreme tyre wear.
Yes there is adjustment. You need to get the alignment checked out. It could be worn bushes and/or damage to the suspension linkages and struts.
SOURCE: ute has just started squeaking
Hello and welcome to FixYa!
Surely the suspension bushings are worn out and needs replacement. I strongly suggest that you replace the shock absorbers too to lessen the stress on bumps. Tie rod bar and tie rod end replacement will be required to make the car stand right again. This will get rid of uneven tire wear.
Hope this helps and thank you for using FixYa! Have a good one!
