The middle light means that the dishwasher is set for a 6 hr delay befor it starts. The light to the left is hi temp wash and the one on the right is control lock press and hold for 3 secondes to lock the controles. You can get the manual on the link below. Page 4
The F(uel) I(njection) comes on when the ECU locates a malfunctioning sensor.You must go to a dealer's workshop to read the ECU's fail report and check the injection components.Perhaps is just a shortcut in your harness but first check the diagnose to eliminate the fact of a sensor or an injector.
Three red lights on the ring of light is an indication of a hardware failure
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall ) If the light is green that means the power supply is OK If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired and shipping and handling will be covered.
