SOURCE: tv digital
You will need to purchase a converter if you do not have sat or cable and desire to bring in off-air channels...accordianman
SOURCE: Apex AT2702
If this happens no matter which input is used (tuner, A/V input rear, A/V input front, S-Video input), then you have a problem with the display itself.
If you get a picture with some inputs but not with others, then you have a connection problem of some kind.
Try plugging a camcorder or DVD player into an A/V input, or a computer into the S-Video input. Do you get a picture with any of those?
SOURCE: Black Screen with sound
make sure the TV time is correct. Reset the time. if that does not work, but the TV operates ok, it's in the circuit board, or could be a fuse problem.
SOURCE: unlock apex tv model # AT2702
Hope that helps..........
try this manual;
[PDF] AT M C T
On the remote try pressing the ( F ) button and the mute button at the same time on your remote control.
Here's the link for the 2402s manual:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=4db1185db9d3369
Pass Code Menu
This menu allows you to change the access code for the Parental Guide
functions of the TV set. Pressing the “Menu” key when Pass Code
Control is highlighted. This will turn on or off the Pass Code function. With
the Pass Code function ON, you can also change the Pass Code. Use
the down arrow key to highlight “Pass Code,” then enter the new Pass
Code using the numeric keypad. Press the left arrow key when finished.
1. The factory default pass code of 6688 is also the override code, in case
you forget your new pass code.
2. The factory defaults have TV-MA and MPAA-X ratings blocked .
Hope this may help you
DON'T FORGET TO RATE:
