Baumatic B180 Electric Single Oven Logo
A
Anonymous Posted on Jun 04, 2014
Bt 3060 oven warm not getting hot enough - Baumatic B180 Electric Single Oven
1helpful
Defy slimline eyelevel oven installed in cupboard.
Assuming it is an electric built in or built under oven, these are commonly fitted into a dedicated cupboard (oven housing) that matches the other kitchen units and typically little or no facility for ventilation is provided.
Electric ovens are usually so well insulated and covered with reflective foil the need for ventilation is minimal, especially when a standard size oven is fitted into the correct standard sized housing as it will provide an air-space of an inch or more all around.
It can be expected the housing near the top of the oven will become warm after a while and the shelf above likely to become warm enough to soften a candle but if it gets hot enough to actually melt a candle I think that is rather too hot. The addition of additional insulation and reflective material should improve matters greatly.
I suggest you approach the guy who fitted the oven if it was professionally fitted. It would have been his responsibility to only fit a suitable appliance and if additional ventilation was required he should have advised you.
I believe I have seen some oven housings with a slim grille over the oven and it is probable there would have also been a slot cut at the rear and perhaps a short piece of trunking to carry warm air away from the space directly above the oven.
Mar 30, 2016 • Ovens
My old Jenn-Air W230 wall oven only gets to "warm" in the bake position - even at a temperature setting at 500 degrees. However the broil function works well. Could the problem be a bad thermostat o
the oven sensor could be bad,its a small rod inside the oven cavity near the top,or you could have a bake element with a "hot-spot" in it that can no longer pass enough current to properly heat the oven to the correct temperature setting(most elements with a hot spot will show a discolored area on the element where its been overly hot)this is the "hot-spot" it will soon break apart there
My kenmore slide in oven gets warm but doesnt get hot enough to bake anything
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
The main oven gets warm but nowhere near hot enough to cook anything. Could it be the element? And if I replace it myself, what is the pen like object attached to a wire at the rear of the oven? Many...
if it gets hot but not hot enough its proberly your thermostat and the pen like thing over the wire is just a cover to insolate the bear spade connection
I turn the oven to 350 degrees and it never gets hot.
First, I guess we need to define hot. If you mean hot enough to bake whatever it is you wanted to bake, then it's possible, if this is a unit that has a "timed bake" feature, that someone neglected to put the control back in manual mode, after having used the "timed bake". If this happened, then the oven will only heat to 160 - 180 degrees, and will maintain that temp. It's called a keep warm setting, which is designed to keep the food that was recently baked, warm, until someone can come get it out and served. Check this feature if you have it and see if it's in manual mode, if not change it and the oven should heat up to 350 and beyond.
If there is NO "timed bake" feature, and there's some heat, just not enough to get to a bake mode, then it's possible that the oven's ceramic glo igniter is cracked and not heating to the point that it allows the oven's safety gas valve to open for gas flow to the burner. If there's no heat at all, the problem could still be the igniter, but it could also be electronic control box feeding the igniter. These things must be checked by a tech with an ohmmeter, and possibly replaced.
Mar 24, 2011 • Ovens
1helpful
The oven is not getting to temperature
Check the breakers/fuses that supply the power to the oven. It sounds like it is not getting enough power.
Oven getting warm but not hot?
If it is an electric fan assisted oven, and the fan is working o/k, \then you need to fit a new oven element., usually located at rear of oven compartment.
Please rate my solution.
Thanks.
Nov 16, 2009 • Smeg Ovens
1helpful
On a Amana EvenAir convection Plus oven the convection blower comes on during the regular bake cycle.
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
Breaker flipped on my oven while cooking a turkey
If the oven was still slightly warm to the touch when you came home is probably fine. 45 minutes was not enough time to get the turkey hot down near the bone, so if it was cool I would discard it. But if you were lucky and it was still warm, go ahead.
Sirwriter - (Smoke and barbecue tons of chickens and capons)
1helpful
2answers
Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 • Ovens
Top Baumatic Ovens Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
How-2-Repair.com
How-2-Repair.com
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
