How do I fix this problem? It says "Can't Make the System File. connect to PC and delete unnecessary file." When I try to connect, I cannot delete any files. When I try to delete from My Computer and from Media Player I also am unable to delete.
SOURCE: Files will not transfer to PC or play when attached to PC
That is a media player error the fix can be downloaded and installed from here
http://www.regcure.tv/free-download.php
SOURCE: Can't use my voice recorder anymore
try to connect the recorder to the PC and with the Olympus DSS Player Version 7 change the folders name to default
SOURCE: "Memory Full" message flashes, even though all files are deleted
Use the reformat option in the menu to completely erase the memory.
SOURCE: Download Files
Hi, I had this problem using a Olympus DS-2300 recorder. I installed the DSS Player Software on my PC and when I tried to download the files from my device to the PC I had this problem.
You will need to check the location of a file called DSSjobNo.dat. The application I think tries to copy this file into the default location for the Download folder, usually somewhere in your My Documents. If it can't copy the file there for some reason then that will stuff things up.
To check where the application is expecting the file you will need to check a value in the registry. This maybe a little tricky so get someone who knows there way around the registry to help you. The location of the entry is HKCU\Software\Olympus\DSSPlayer2002\Dictation Module\download\InstallSetting The value is JobNoFilePath and will hold the path to where the application is expecting the dssjobno.dat file.
Armed with this knowledge you can then check if the dssjobNo.dat file is in that location. If not copy the file from C:\program Files\olympus\DssPlayer (this is where I found the file on my PC) to the location the registry entry specified.
Or if you know what you are doing you can change the reg entry to go to the location you want the file to be in. Useful in my case as I wanted the download path for my files to be on a shared folder on the network and I wanted to keep it all together.
Hope this helps!
SOURCE: won't record, looks empty, but says it's almost full
Connect the recorder to your mac and empty the trashbin
