Hello Friend, this is Z. Thank you for allowing me to assist you!
I see that your Frigidaire washer (ATF6000FS1) door will not unlock. Sometimes, resetting power to your washer for about to 10 minutes does the trick. Once you turn on your washer, select a normal cycle and verify if the door will unlock. If not, your washer may possibly have a faulty door lock assembly, or a communication problem with the control board. You may want to connect with a local servicer who will be best equipped to pinpoint the problem. If you don't know a qualified technician, you can use the service locator option on the manufacturer site to find one near you.
