Konica Minolta bizhub C250 All-In-One Laser Printer Logo
A
Anonymous Posted on Jun 04, 2014
8650 machine error 21 - Konica Minolta bizhub C250 All-In-One Laser Printer
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Dec 28, 2015
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1913835
Points
11960
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
Hope fully not the last two expensive.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Lavazza LB2300 writes error 21. How to eliminate it?
Switch machine off and back on. The water didn't hit the sensor fast enough.
The machine does not detect the water flow in the circuit
The water circuit is interrupted The alarm can be reset by switching the machine off
Service Manual Page 37 refers.
https://wiki.wholelattelove.com/images/3/3f/BLUE_2312_Service_Manual.pdf
Hi Washing machine BOSCH Maxx 7. Displays error F 21. What's wrong - and what can we do ? sincerely,Jette
The F21 error code indicates that you have a problem with the washing machine's motor.
Have it checked out by competent electrician.
What does the error code F 21 mean
F 21 indicates a drain problem.... mostly due to a clog. Google
washing machine F 21 code. There are many links including
repair videos. Good luck to you.
Regards,
Dennis
LID CLOSED STILL SHOP LID AS AN ERROR
Looking from the back of the 8650 counter with the lid open, there is a safety switch on the left side. It is either not pressed in when the lid is closed or it is broken. To test, take the two wires from that switch and connect them together. That will by pass the switch and allow the machine to work. Good luck.
8650 p21 p6
p 6 cyan image unit replace
p 21 Color registration problem is P 21. Need to do a color registration procedure.
Minolta 8650 problem c-2a01
loo like you replaced the cyan toner cart.. (with the machine powered off and unplugged) take a look inside the machine with the cyan toner cart out.. make sure that nothing is blocking the metal contacts or if there are dirty contacts. perhaps there is a piece of debris that is blocking the connection of the new toner cart to the printer. another thing to check is the contacts on the toner cart its self.
The motor on my riccar 8650 is very loud. is there brushes that can be replaced?
Your. 8650 is likely well over 20 years old. It has carbon brushes in the motor that may need replaced but your best bet Is to take it to your Riccar dealer to diagnose it or you might replace the wrong thing. You have a very durable long lasting machine obviously but there are minor things that need occasional service to keep it running properly for many more years. This series started with the 8600 models of which I still have many brought in for annual service. There has been an 8700 and 8800 series and now the latest 8900 series which has been out well over 10 years.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
