SOURCE: Cannot pull out spout to replace o'ring of Kohler Faucet 10416
the pic u have up doesnt show it being a pull out u trying to fix airater?
SOURCE: kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
SOURCE: Low flow from Kohler K15160 spray kitchen sink
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
SOURCE: Single Handle faucet broke on my Kohler kitchen
Is cheaper to replace the whole tap as the service kits cost almost as much as the tap to buy, I presume you are talking about a flick mixer tap (that is what they are called in australia)
Replacing them is reasonably easy, turn off water at the main out on the footpath turn the tap on to let the water run out, go under the sink with a couple of spanners or deep reach socket and undo the lines and the tap hold down nuts and remove, replace in reverse order
SOURCE: how can be removed the bonet of de Kohler kitchen
try this if you need more help just ask... THX
http://www.us.kohler.com/onlinecatalog/pdf/1011154_2.pdf. The bonnet is screwed on and this should give you what you need. If you have any trouble just ask.
