Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Click'n connect can't discover the router d link
2 Suggested Answers
SOURCE:
dheeraj_rank
SOURCE: help with d-link router please
i am having the same trouble so please help me guys
Posted on Feb 08, 2013
Help with d-link router please
Thanks, konafaa. Sometimes the best procedure is to start over from the beginning, as you discovered.Best regards!
Apr 19, 2012 | D-Link Computers & Internet
How do we secure our Wireless router Up until we have been using a cable router and now wish to use a DSL-G604T model which is up and running but in an unsecured mode.
1. Navigate to router's web interface<br /> 2. Login, click to Wireless button<br /> 3. Select WPA radio button as Security<br /> 4. Select Pre-Shared Key radio button and type some password to PSK String field<br /> 5. Click Apply button<br /> 6. To save and reboot the Router, click on the Tools directory tab and then click the System button. In the System<br />Settings window, click the Save and Reboot button under Save Settings and Reboot the System<br /> <br /> DSL-G604T doesn't have built in MAC access list and may hang on heavy usage. To optimize it for stable and safe connection use Router Commander program from <a href="http://www.routercommander.com">http://www.routercommander.com</a>, with it this router shows very good <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: HE">performance </span>and stable internet connection.
Aug 17, 2010 | D-Link DSL-G604T Wireless Router
Hi i am getting an error message clinkn connect can't discover router. please check the cable connection and make sure the router is powered on
This could be a cable fault.You can buy simple cable checkers at aPC store.If this isn't faulty,try uninstalling and then reinstalling the disc that came with it or going to device manager clicking on modems and seeing if your router is there if it is right click on to it and click update driver.RESTART THE COMPUTER.
If this didn't fix it,try unistalling the modem from device manager restart the computer and the windows system will try to find a driver for the modem.Or you could try searching for the driver in browse when you update the driver.IT GETS COMPLICATED I KNOW I'VE DONE IT THOUSANDS OF TIMES.WINDOWS 7 IS A GOOD OPERATING SYSTEM THAT FINDS DRIVERS AUTOMATICALLY FOR YOU.
IF YOU AINT GOT IT GET IT NOW.UPDATE YOUR PC.
Aug 07, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Click'n connect can't discover the router message in Quick Insta
1. If you have a modem, connect the modem to the router(make sure modem should be connected to the port on which LAN, Internet, WAN is mentioned. It would be a separate one port on the router) and router to the computer.
2. Insert the disk that came with the router, inside the computer.
3. Follow the on screen instructions.
4.No, connect to the wireless.
May 15, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
How to Install DLink DIR-615 with only 1 port on my laptop?
Connect the modem to the router via the ethernet cable. Connect the laptop to the router by means of another ethernet cable in one of the 4 spare sockets. Switch everything off. Turn everything back on one at a time, modem first, then router, then laptop. Allow each unit to fully power up before switching the next one on. Put the installation CD in the laptop and try again. If you are using the laptop wirelessly, make sure the wireless function is switched on!
Apr 12, 2009 | Computers & Internet
Can not connect to wireless router type P-660HW with vista
To resolve this issue, disable the DHCP BROADCAST flag in Windows Vista. To do this, follow these steps:
1. Click Start
Collapse this image Expand this image
Start button
, type regedit in the Start Search box, and then click regedit in the Programs list.
User Account Control permission
If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
2. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{GUID}
In this registry path, click the (GUID) subkey that corresponds to the network adapter that is connected to the network.
3. On the Edit menu, point to New, and then click DWORD (32-bit) Value.
4. In the New Value #1 box, type DhcpConnEnableBcastFlagToggle, and then press ENTER.
5. Right-click DhcpConnEnableBcastFlagToggle, and then click Modify.
6. In the Value data box, type 1, and then click OK.
7. Close Registry Editor.
8. restart your computer
By setting this registry key to 1, Windows Vista will first try to obtain an IP address by using the BROADCAST flag in DHCP Discover packets. If that fails, it will try to obtain an IP address without using the BROADCAST flag in DHCP Discover packets.
Nov 28, 2008 | Zyxel Prestige 660HW Wireless Router...
No internet connection through router D-Link DI-524
-Connect your router to the wall and connect your laptop to the router using a cable.
-Use Internet Explorer and type the following line in the address bar: http://192.168.0.1
-You should see a Username and Password Screen...type admin for the username and leave the password blank, unless of course you did give it a password.
-Next you should see the D-Link setup page with tabs across the top that say Home - Advanced-Tools-Status-Help
-Click on the WAN button on the left side of the screen
-Now you should see the WAN Settings Screen
-Click on "Dynamic IP Address" (You should not use PPPoE)
-Click on the Apply button at the bottom of the screen.
-Now close your browswer and restart your computer.
-You should now be able to access the Internet...through the router cable and wireless
-Let me know if you need more help with any of these steps.
-Good luck...and I hope this helps!!
Jan 14, 2008 | D-Link AirPlus DI-524 Wireless Router
No Internet Through the Router
If changing from a dial-up connection, see warning at bottom. Troubleshooting Steps 1. Connect your computer directly to the modem, without the router. If you cannot access the Internet, contact your ISP. 2. Reconnect the router, modem, and computer as they were before Step 1. Can you log on to the router? If not then: 1. Check that all cables attached to the router and computer are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot light status, as explained in the router manual. 3. Check the LEDs for the ports with cables are lit. If not, move the cable to a different port. If there are still no lights, then troubleshoot light status, as explained in the router manual. 4. Check if the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue this document. If the adapter is not NETGEAR's, contact the manufacturer. 5. Power off the router. 6. Power the router on again. 7. If you still cannot log on to the router, then do a hard reset on the router, as described here: http://www.fixya.com/ThreadView.aspx?thi... 8. If you still cannot log on to the router, Contact NETGEAR: http://kbserver.netgear.com/kb_web_files... . 3. Run the router's SmartWizard. This lets the router discover whether you have a static or dynamic IP address, and whether you are using PPPoE to connect to your ISP. (For routers without this utility, go to Step 7.) 4. If a dynamic IP address is discovered, go to Step 8. 5. If PPPoE is discovered, configure your router with the username and password from your ISP. Click Apply to enter the data. Go to Step 8. 6. If a static IP address is discovered, configure your router with this information given by your ISP: the IP address for your router, the address of the ISP's DNS, and the address of the gateway. Click Apply to enter the data. Go to Step 8. 7. If the Smart Wizard does not find an IP address: 1. Power off the router. 2. Power off the modem. 3. Power on the modem. 4. Power on the router. 5. Go back to Step 3. 8. Click Test to access NETGEAR's online test page. If the page displays, then you have Internet access! 9. If the page does not display in a minute, check here: http://www.fixya.com/ThreadView.aspx?prd... . 10. Find out if the modem's IP address can be seen by looking at the Router's Status Page, as described in the manual. If not, then reboot the modem, router, and computer, in that order ? waiting for each to completely reboot before rebooting the next. 11. If the modem's IP is seen, then there is a problem with your browser's settings. Your security may be set too high for the Internet service you are trying to use, or your browser may be configured for a dial-up connection. In Internet Explorer you check this using Tools > Internet Options > Security > Default Level. If the slider is set to "High", change it to "Medium". Click Tools > Internet Options > Connections. If the radio buttons in the center are not greyed out, then settings for a dial-up connection are being used. Warning: If you are a dial-up user converting to a cable or DSL connection, some software will not work when both types of configuration are present. Configuring your new connection may stop your dial-up connection from working. You may have to configure to connect one way or the other.
Feb 19, 2006 | NetGear FM114P Cable/DSL ProSafe 802.11b...
Feb 19, 2006 | NetGear RP114 Router
If changing from a dial-up connection, see warning at bottom. Troubleshooting Steps 1. Connect your computer directly to the modem, without the router. If you cannot access the Internet, contact your ISP. 2. Reconnect the router, modem, and computer as they were before Step 1. Can you log on to the router? If not then: 1. Check that all cables attached to the router and computer are secure. 2. Check the Internet LED is lit. If it is not, troubleshoot light status, as explained in the router manual. 3. Check the LEDs for the ports with cables are lit. If not, move the cable to a different port. If there are still no lights, then troubleshoot light status, as explained in the router manual. 4. Check if the LED on the Ethernet adapter is lit. If it is not, then troubleshoot the adapter, do not continue this document. If the adapter is not NETGEAR's, contact the manufacturer. 5. Power off the router. 6. Power the router on again. 7. If you still cannot log on to the router, then do a hard reset on the router, as described here: http://www.fixya.com/ThreadView.aspx?thid=102071&prdid=252225. 8. If you still cannot log on to the router, Contact NETGEAR: http://kbserver.netgear.com/kb_web_files/n100005.asp . 3. Run the router's SmartWizard. This lets the router discover whether you have a static or dynamic IP address, and whether you are using PPPoE to connect to your ISP. (For routers without this utility, go to Step 7.) 4. If a dynamic IP address is discovered, go to Step 8. 5. If PPPoE is discovered, configure your router with the username and password from your ISP. Click Apply to enter the data. Go to Step 8. 6. If a static IP address is discovered, configure your router with this information given by your ISP: the IP address for your router, the address of the ISP's DNS, and the address of the gateway. Click Apply to enter the data. Go to Step 8. 7. If the Smart Wizard does not find an IP address: 1. Power off the router. 2. Power off the modem. 3. Power on the modem. 4. Power on the router. 5. Go back to Step 3. 8. Click Test to access NETGEAR's online test page. If the page displays, then you have Internet access! 9. If the page does not display in a minute, check here: http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102076 . 10. Find out if the modem's IP address can be seen by looking at the Router's Status Page, as described in the manual. If not, then reboot the modem, router, and computer, in that order ? waiting for each to completely reboot before rebooting the next. 11. If the modem's IP is seen, then there is a problem with your browser's settings. Your security may be set too high for the Internet service you are trying to use, or your browser may be configured for a dial-up connection. In Internet Explorer you check this using Tools > Internet Options > Security > Default Level. If the slider is set to "High", change it to "Medium". Click Tools > Internet Options > Connections. If the radio buttons in the center are not greyed out, then settings for a dial-up connection are being used. Warning: If you are a dial-up user converting to a cable or DSL connection, some software will not work when both types of configuration are present. Configuring your new connection may stop your dial-up connection from working. You may have to configure to connect one way or the other.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
26 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
