SOURCE: furuno gps wiring diagram for usb
Hello!
I have the connection diagram for the GPS unit below. It should be simple to wire up. You will need a USB to RS-232 converter, which is available in a number of computer shops/Radio Shack.
Hope this helps you out,
Ken
SOURCE: may i upgrade furuno 1920 gps/ploter with radar
If it has a round radar plug in the back then the answer is yes and it already has radar support. However to upgrade your unit to the latest software you will need a dealer for that. It's a very tricky process and if not done properly, you can ruin the bootloader programming that starts the unit. I know of a dealer that does this if you want to check in with them. You can even send them the unit. Try www.mid-shore-electronics.com.
