I have a touch screen acer aspire laptop. The screen works and my touch pad works to scroll, but I can't select anything using my touch pad. How do I get it to work
SOURCE: Not working right click of touch pad of Acer Aspire 4710z
Hey!
What operating system are you running? All I could find was a manual for your model: http://tinyurl.com/6gc7pl
If you are using Windows XP, you might try going to Control Panel -> Mouse -> On the first tab (Buttons) check "Switch primary and secondary buttons." then hit "Apply".
Try left-clicking (currently assigned to be the right-click) on your Start button and see if the menu with "Explore All Users" on the very bottom opens. If it does, then your touchpad is most likely defective and would have to be fixed (www.fixmyacer.com). If the menu doesn't come up, then it is a software issue and is 100% fixable.
Matt Newelski
www.newelski.com
SOURCE: I have a Acer Aspire 7720 laptop,
Hold down the FUNCTION (FN) button and hit F7to turn your touchpad on or off.
SOURCE: HP Pavilion dv8000 - touch scroll pad won't work
at the top black rim around the touch pad, there is an orange light showing, press and have it show blue. It will work now.
Cheers.
Please rate this fixya.
SOURCE: my laptop touch pad stopped working, it wont move
Try Fn+F7 to reenable the touchpad. Might have been disabled by mistake.
SOURCE: Acer Aspire 5315 Touch pad problem
go to the control panel, mouse configuration , and try to turn on the touch pad
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Need to know which model you have and have you tried a recovery to make sure its not software ??
