Before spend $$ on replacement boards, make sure anything attached to it is powered off. Unplug TV for 5mn to 15min. Plug back in and it should power on. If not leave unplugged overnight before spending on a replacement board. We have to do this 2-3 times per year when someone forgets to turn off auxiliary components (receiver, DVD, cable box, etc) first. It has always come back on.
Hello, you can reset the battery, battery off, after 45 second push down the power botton for 5 secund and release,then put it back the battery and try turn on ,if don't working,you can try follow this link to change the battery. Amazon com Gateway 7320gz Laptop Replacement AC Power Adapter Includes...
The reason the light flashes, is because the tv is still on, that is the fan is cooling off the lamp. It will go off after about 1 minute. This is normal.
If you know basic electronics and can recognize parts inside receiver, then I'm here to help you but please don't call it as junk. Its beautiful piece of Aiwa.
Receiver turns on Green but on pressing button again for red light standby, red light will not come on for this Denon receiver. Recently light came on saying Panel Lock is on. I was not able to get tuner to work.
it wasn't working for me either , but the directions I received wasn't as accurate as some I've seen lately.
Ensure:
Press mode and reset(lap) at the same time for at least 3 sec. (make sure you press it till you hear that click)
after more than 3 sec. let both go
now press the power button and let go
wait 3-5 sec, then it will power up-
repeat if it doesn't work the first time, the key for me was hitting the power button after the reset and waiting for up to 5 sec after releasing the power button
the issue is getting it to work the way it should!
at the time the hard drive problem came up the receiver would of went into recovery mode this can take a good hour for it to fix and can do nothing until it would finish on its own and take care of. Doing the power reset is just like unpluging the receiver. Try unpluging again for 30 minutes and plug back in again and just wait receiver should come back on its own. Don't hit any buttons. If not will have to send out to dish for repair. 800-333-3474 dish
