LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
A
Anonymous Posted on Jun 03, 2014
ALL SETTING SERVICE MENU MODE - LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
Menu segreto hannspree hsg1113
http://translate.google.com
Secret service menu Hannspree HSG1113
https://electronicshelponline.blogspot.com/2015/03/hannspree-lcd-tv-how-to-enter-service.html
Possible menu - Quoting from link above:
SERVICE MODE [Hanspree AT06 42" LCD TV] (Horizontal Frequency 31.5KHz to 48KHz)
* In the TV mode, adjust volume to Zero and press number keys 9 > 8 > 7 > 6 to enter service mode.
* To exit, press the EXIT button on the remote control.
SERVICE MODE (Hanhspree GT02 32E - GT03-37E1)
1 Switch on the LCD TV .
2 Press 9-9-1 on the remote control to enter the internal Service menu.
3 Press MENU to switch the service mode pages.
4 Press ?? to scroll through the various menu options.
5 Press ?? to change the menu settings.
6 Press MENUto save the new settings and switch to next page and press EXITto exit from service mode to normal mode.
TV / AV / S-VIDEO / WHITE BALANCE / BRIGHTNESS & CONTRAST ADJUSTMENTS
WHITE BALANCE ADJUSTMENT
1 Press 991 on the remote control to enter the internal Service menu.
2 Press MENU to switch to the PW106 Scaler Menu page
3 Press ?? to scroll to Page 2-3 options
4 Press ??
to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings.
5 Press EXIT to save the new settings and exit. [Don't adjust others setting in page 2-3]
Click on the Pictures to Zoom In
BRIGHTNESS ADJUSTMENT
1 Repeat the above mentioned step 1 to 2
2 Press ?? to scroll to PW106 FE VDC Menu Page 2-1 options
3 Press ?? adjust the Brightness setting.
4 Press ?? to scroll to TV/AV/S Parameter=AV1 setting and pressuto run the setting. (This procedure will copy the settings of AV1 to S & TV)
ATSC DTV WHITE BALANCE / BRIGHTNESS / CONTRAST ADJUSTMENT
2 Press ?? to scroll to PW106 Scaler Menu Page 2-3 options
3 Press ?,? to adjust the Offset Red, Offset Blue, Gain Red, Gain Blue menu settings
4 Press to save the new settings and exit. [Don't adjust others settings in page 2-3]
YCbCr & YpbPr of COMPONENT 1, 2 WHITE BALANCE/BRIGHTNESS/CONTRAST ADJUSTMENT
Getting COMPONENT-1 connect to 1080i signal. (The settings could not be saved if signals input from COMPONENT 2 or connect to other sources such as 720P, 480P, 480i,etc.
WHITE BALANCE ADJUSTMENT OF Component
1] Repeat the above mentioned step 1 to 2
2] Press ?? to scroll to PE106 FE ADC page 2-3 options
3] Press ?? to adjust the Offset Red and Off Blue settings.
4] Press ??to adjust the Offset Green setting.
5] Press ?? to adjust the Gain Green setting.
6] Press ?? to scroll to 480i/480P/720P Parameter=1080i setting and press ? to run the setting. (This procedure will copy the setting of 1080i to 480i/480P/720P)
7] Press EXIT to save the new settings and exit.
WHITE BALANCE ADJUSTMENT OF PC INPUT
1.Connecting to VGA Timing mode
2.Under service mode, Press ?? to scroll to PE106 FE ADC page 2-2 options
3.Press ?? to adjust the Offset Red, Offset Green and Off Blue settings.
4.Press ??
to adjust the Gain Red and Gain Blue settings.
5.Press EXIT to save the new settings and exit.
Ricoh SG 3100DN error code SC 28211, what is that and how do I repair?
http://www.copytechnet.com/forums/ricoh-savin-gestetner-lanier/96767-ricoh-sg-3110sfnw-showing-sc28211-error-code.html
Did not report a solution, but quoting from link above:
Ricoh Sg 3110sfnw showing SC28211 error code
Ricoh sg3110 sfnw showing sc28211 error code.
In trying to Execute carriage change sp mode (3-009-002), I cannot find 'Engine setting' (which according to the service manual) supposed to be under 'Printer setting' menu from Service mode.
Can someone help on step-by-step procedure of getting to the "Engine Setting" (sp mode) menu please in case am omitting something along the line or is their a permission required?
1helpful
Bizhub Pro C 6000 L. What does error Code C 3505 indicate?
Fusing high temperature abnormality The temperature sensor /1 (TH1) detects 150 °C or higher value continuously for a specified period of time.
Reset attempt once if the code comes back call a KMBS Tech
1. Be sure that the ordinary operation screen is displayed.
Press [Utility/Counter] button.
2. "Utility screen"
On the Operation panel, press the following buttons.
Stop ? 0 ? 0 ? Stop ? 0 ? 1
When the CE password has been set, entering the password is required to enter the service mode.
3. "Service Mode Menu screen"
The service mode appears.
select 03 System Setting
• 01 Software DIPSW Setting
Be sure to set the DIPSW3-1 to 0 after replacing the defective parts. If DIPSW3-1 is set to 0 before defective parts are fixed, it
may cause fire. DO NOT RESET MORE THEN ONCE COULD CATCH ON FIRE AT WILL RUIN A PERFECTLY GOOD DAY
To exit:
Service Mode menu screen"
Press [Exit] to back to "Utility screen".
2. The new settings become effective
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to reset konica bizhab 164 m2
press menu quick setting << quick setting <> (service mode) go to service choise and go to maintenanc 0 ok press back IU LIFE STOP MODE press continues . press back go to clear data go to maintenac clear and supplies clear ok power off and on
Lg rt 21fd 55 vq problem regarding service menu colour setting i need factory setting guid me
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Bizhub 920
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
The soft switch you want is 03 -1-0
with the code it will be 03-1-1
1. "Service mode menu screen"
Press [07 System Setting].
2. "System Setting menu screen"
Press [01 Software DIPSW Setting].
3. "Software DIPSW Setting screen"
Press the [?], [?] or the numeric keys to select DIPSW bit number.
4. Press [On (1)] or [Off (0)] to set the selected bit number ON/OFF.
5. Press [Return] to return to the "Service mode menu screen" on which the sub menu was displayed.
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
4helpful
Waste ink is full how to clear this message
a) How to enter Service mode
Follow the procedure below to enter Service mode.
1) Turn off the printer.
2) Turn on the printer while holding down the [Paper Source] button and [Online]
button.
3) Check that "Canon W8200" is shown on the display, and then release the buttons.
4) Next, "SERVICE MODE" is shown on the display. (If sheets are inserted, this will
be displayed after the sheets are loaded.)
5) Use the [Lower arrow] button to make a selection.
Service mode is added to the options in the Main menu.
Service mode can be entered even during error status (when Exxxx and Wxxxx are
shown on the display) by turning the power off and then using the above key
operation.
b) How to exit Service mode
To exit Service mode, turn off the printer.
c) Buttons used in Service mode
• Selecting menus and parameters: [Left arrow] button or [right arrow] button
• Entering a lower-level menu: [Lower arrow] button
• Entering a higher-level menu: [Upper arrow] button
• Setting menus and parameters: [Enter] button
Now under service mode select counter, and select printer and W-INK to reset it, and under initialize select W-INK.
But also change the waste ink absorber so that you do not get waterfalls of ink from your plotter :-)
Hope that helps
2helpful
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
