THE FANS WORK BUT NOTHING SHOWS ON THE MONITOR AND ITS QUIETER THAN USUAL
1.Cooling fans work?
2.No Signal shown on monitor?
3.Harddrive doesn't make any noise? (To explain. Harddrive is inactive. Not spinning, and the arms aren't moving back, and forth across the platters)
Suggest it's a bad power supply. A common occurrence.
Why?
1.Owner fails to keep the inside of the computer clean, and the power supply.
Dust/Dirt/Spider Webs/Lint, you name it, builds up inside. This foreign material clogs up cooling components. Specifically the Processor fan, and Heatsink, plus the power supply fan, and heatsink's inside the power supply.
Result?
Processor heats up. Takes more power to run, until eventually it turns off. (Processor's have a thermal limit. Once this thermal limit is exceeded, BIOS turns the processor off)
Power supply heats up. Fan blades and center hub collects Dust/Dirt, as well as heatsink's inside the power supply. Cooling capacity drops tremendously.
Heat = Wasted Energy. The power supply puts out more, and more power to keep up. Eventually components inside the power supply fail. They burn up. (More on this to follow)
2.Cheap power supply. Cheap construction, and cheap materials used. Pre-built computer manufacturers generally use cheaply made power supply's. Saves them money.
A.Gauge of wiring used inside is too small.
B.Electrolytic Capacitors used are of an inferior design, and of cheap quality.
C.Circuit design is below par.
D.Other components used are of low quality.
So how does a bad power supply still light-lights, and spin fans?
Bad power rail.
Personal computer power supply's put out three main voltages.
A.12 Volts
B.5 Volts
C.3.3 Volts
Electrolytic Capacitors used in a power supply are Filters. They filter the incoming AC electricity, and the rectified DC. When one or more capacitors fail, or are failing, a bad power rail results.
1.ALL the lights uses less than 1 Watt.
2.EACH fan uses 2 to 3 Watts.
A typical Processor uses 55 to 125 Watts. Depends on which processor it is.
So you see, you can have enough power to light those lights, spin fans, and even spin the harddrive motor, but not enough to turn the processor on. (Or if it does turn on, not enough to keep it running)
You can easily prove it's the power supply at fault, if you have a known, good, power supply to use for a test.
Another 300 Watt unit that has the same power cables. (Should be stated as has at LEAST the same power cables. It can have more power cables, and these just won't be used)
No processor running you get no signal to the monitor. Computer isn't working to give a signal to the monitor.
Computer is quieter than normal, because you don't hear any harddrive noise. No processor running to access the Operating System on the harddrive. (Or programs and applications)
(Windows XP is an example of an Operating System. O/S)
Just for information, this link gives details of the components inside a harddrive. Gives you more info about the Arms, and Platters I referred to above.
Just thought I would include it. It is not advertising for this website, but is included for reference.
http://computer.howstuffworks.com/hard-disk.htm
