We turned it on a week ago and the picture was upside down and a little scrambled. We unplugged it and plugged it back in and it went back to normal. Lately it is taking longer for it to turn on and turning it on and off doesn't do the trick.
SOURCE: rca scenium
you are having a problem in your power supply, standby power supply where the microchip is situated take the set to a tech to have it repair.good luck.
SOURCE: my rca 32" flat panel tv model l32wd22 won"t turn on
i have a l32wd22 rca -----went out -- the plug from the power cord to the power supply [ a two prong jack on the side of power supply was loose]
i bent the pins slightly then plug it back in and also taped it in place---now it works fine
SOURCE: RCA L26WD12 26IN, LCD TV will not turn on, the red
It can be due to unstable DC power from the power supply due to bad caps, or bad main board (I had to replace my main board, and later on the inverter boards). You may want to think about putting money into this TV.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
http://s807.photobucket.com/albums/yy352/budm/RCA%20L26WD12/
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
SOURCE: My RCA TV (Model L32 WD 22) was purchased almost 3
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty
was Expired) and found several faulty capacitors on the PSB. Its
pretty common. Major Electronic companies were sold faulty capacitors
that fail in 2-5 years instead of 10-20 due to a lack of
preservatives. It wouldn't surprise me if you have the same problem.
TV will work fine for a few years and then just fail completely or
slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
