1) Lube the deck belt, maybe you have a worn deck belt, use 100% silicones or wax, check your instr. manual
2) Lube the rollers bearing with wd-40 very well
3) Test the drive belt motor, for cracking or worn belt
4) Test the input voltage motor, if there are the motor need repair, please go to my personal TIPS for motor help
5) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty, see the block dia
God bless you
