My steam generator has suddenly stopped producing steam
SOURCE: I have a morphy richards
The white stain is due to mineral build up on your iron.
Try flushing the iron with a vinegar solution to dissolve the mineral deposits then purge with demineralized water. Only use demeralized water in your iron. The first time you may want to test it on a scrap piece of cloth to insure all of the minerals have been removed.
SOURCE: Morphy richards jet steam iron.
my morphy richards steam genarator iron 42242 says it is hot enough but in fact sole plate is not and leaking water over garments.any ideas?email me [email protected]
SOURCE: My Morphy Richards Jetstream is about 5 or 6 years
Try cleaning the inside of the water holder it might just be calcium built up, use white vinegar to clear it and you'll prolly be fine. Put vinegar where you usually put the water and heat the iron up and steam the vinegar through the iron then put water, try distilled water to save this problem from happening again or try filtered water.
SOURCE: How to descale your morphy richards jet stream 42271 iron
you must read your owner manual section maintenance or troubleshooting , or get contact support from the factory, via chat or phone.
God bless you
SOURCE: morphy richards iron lights up all fuctions working but does not hot
1( test the outlet wall , put some lamp if there are light
2)test the power cord.
3) test the thermostat
God bless you
