SOURCE: cable traction needs adjusted
To adjust the self propel cable, loosen the cable
clamp, pull the cable downward to remove all the slack
then push the cable jacket up 1/8”
and secure with the cable clamp
good luck
SOURCE: I HAVE A TORO SP
It sounds like the cable still needs more adjustment. The cable needs to be tighter. This is going to be hard to explain by typing. But I will give it a try. When you pull the handle in about 1/2 way mark the place where the lever on the drive motor is at. And take the cable loose and reattach the cable back to the mark that you made previously. So when the bar is released, it is like it is pulled in half way now. I hope that this makes sense. Let me know if I need to try to explain more.
SOURCE: I own a toro zero
pull the plug out get , turn mower just past tdc, pull the cover off and adjust ure valves what model is the kawi
SOURCE: how to replace drive belt on self propelled toro commercial push mower
the should be a plastic cover under the engine
