The problem is simple if u were to read the JBL Powered Sub Manual. the JBL has a circuit that shuts down the amp if it detects a battery voltage of 10volts or less. with your two batteries strapped together its detecting the low voltage from your accessory battery rather than the full voltage of the secondary battery. fyi if u were to read the manual it does say to connect the black and red wires directly to your boats battery. id get a volt meter and with the boat and all its accessories running check the output voltage of each battery. which ever battery has over 10v thats where u want the amp hooked up....
If a boat is anything like a car, the amp's negative post should not be connected to the battery, but to the ground of the boat. In a car, the entire chassis is grounded to the negative terminal, so when you run a line from the positive terminal of the battery to the positive post on the amp, and a line from the negative post on the amp to the chassis it is a complete circuit. I highly recommend placing a fuse on the positive line from the battery to the amp. Wiring this way prevents the amp from blowing up your battery, as well as prevents the battery from blowing your amp. Hope it works.
I'm not 100% certain if it will work, but if not, I would say try searching Google or something online for marine audio hookup diagrams, you may be able to find something that will help you troubleshoot. Is a marine battery also 12V like a car battery?
Well in a car, the whole thing is steel, so anywhere metal is connected to the battery, so connecting the amp to a metal part of the car is indirectly hooking it to the battery. I see what you mean, though, I have one other thought, and that is that there is a problem with the remote turn-on line. Once I had a stereo that didn't send out a remote turn on signal, I just ran a lead off the positive cable to the remote spot on the amp, with a switch so I could turn it on and off. I don't know if that will do anything, it doesn't seem like that would have anything to do with the problem since the amp does turn on sometimes. Sometimes electronics can act up at times, and things that hardly make sense end up solving the problem.
I'm not sure how the ground difference works, but we'll give it a try. the radio + line does already have a fuse. We'll add a fuse to the amp + line and move the ground to another point.
thanks
Yes . . . a marine battery is 12 volts like a car battery. The challenge for me in this is that since a boat is fiberglass and not steel, move of the other electrical circuits on the boat eventually tie into some cable or wire that eventually goes to the negative post. I can move the ground off the post directly, but I believe it will still be back there indirectly.
The stereo has two positive power leads . . . one is a larger "power" wire and the other is just labeled as a "switched power" line. The switche dline is supposed to be hooke dup to the ignition, or something so the radio can't play unless the accessory switch is on. Becasue my son wanted the radio to play regardless of whether the key was on or not, he wired both of these stereo power wires into the same hot wire coming from the battery. Do you think that this switch wire having power all the time could be causing the stereo to be "confused"?
Thanks
Put the wiring to the primary battery - as the backup is just that - a backup for emergency starts. This will end your problem.
