AT STANDBY MODE GOES RED AND WHEN YOU TURN IT ON GOES GREEN (NO PICTURE)THEN GOES BACK TO STANBY (RED)AGAIN.
This sounds like the typical bad capacitors in the power supply. If you look at the power supply you will find capacitors bulging at the top of them. these will need to be replaced. if you have electronics repair experience then do it yourself, if not, refer the repair to a qualified service technician. replacing capacitors incorrectly can result in damage to your set.
It must be a problem with the router box what is your tv servace what is your provider (dish charter tds etc.)
SOURCE: power light blinking green and cannot turn off or display anythin
power inverter board is dead.
need a new one.
SOURCE: aquos lc-32d44e 11 months old. red power light is
It is still under warranty, take it to sharp authorized repair service.
SOURCE: my sharp lc 32d42u shut off and won't turn back on
IF YOU STILL HAVE SOUND I AM PRETTY SURE WHAT THE PROBLEM IS...
SOURCE: Sharp Aquos LC-32GD8E-picture goes off at random
I had the same problem with the Sharp Acquos LC-32GD8E. A repair man was able to fix this by opening up the back cover and tightening the metal (ground) shield. the screws seem to have come lose. If I had known this I would have done it myself!
