Stephanie, could be a faulty charger or battery, try and borrow a friends charger if you can and try and see if it charges then you know your charger is bad, if it does not charge the your battery needs replaced.
PRESS THE HELPFUL BUTTON
With the charger hooked up and plugged in the tablet will only show the battery on the screen briefly to let you know it's charging. It won't actually boot up until it has a sufficient charge. Just let it set that way for a couple of hours then try to power up.
If it wont turn on how do you know it is charged ?. Are you sure the charger is working ?. connect the charger does the tablet show it charging ?. Over time I have replaced many faulty chargers .
If you have the correct charger, let the tablet charge for a full 24hrs, actually i think 10hrs will be ok and try turning it on, also you can google how to do a reset for your exact model tablet. I have another brand tablet and that worked.
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
It may be the charger has a loose wire. In that case a new charger would fix the problem. Mine has a problem with the charging port itself. I am fortunatly that my tablet is under warrenty they are going to replace the tablet for me.
