Dewalt DPD3100 Gas Pressure Washer Logo
Alexandria Gamble Posted on Jun 04, 2014
Why do i loose pressure after a few minutes - Dewalt DPD3100 Gas Pressure Washer
djdavelong
Level 1:
  • Contributor 5 Answers
  • Posted on Jun 04, 2014
djdavelong
Contributor
Level 1:
Answers
5
Questions
0
Helped
1497
Points
15
Quite often it means that your water supply is too small... not enough gallons / minute.
What's cause to lose pressure for a few minutes then pick back up
Usually low fluid causes pressure drops. In everything. Type of vehicle and what is loosing pressure helps.
1992 zzr 600 oil leak for a few minutes after starting
The easiest way to find an oil leak is to start with a clean engine. Clean the engine with a good degreaser (I've found the citrus based cleaners to be very good) while engine is warm (not hot) and let the degreaser sit on engine for a few minutes (follow instructions on bottle). Rinse off engine with high pressure water and let dry. Watch engine while a helper starts bike. The oil leak should be evident. The most likely culprits are a loose oil filter, oil pressure switch or an oil line, so pay particular attention to these.
Oil light comes on and goes off every few minutes. why does it do that?
need more info is there enough oil in engine? if so check oil sending unit to see if wire is loose if ok have oil pressure checked with oil pressure guage to see if oil pump is weak
Drive the car then it looses power as if no petrol to the engine
run fault codes and look for sensor problems. Have a pressure test done on the fuel manifold to check fuel pump/pressure regulator and filter.
97 pontiac grand am gt runs for a few minutes then shuts off
Put a fuel pressure gauge on it & see if you have or loose
fuel pressure
If it stays running, take it for a drive with the gauge taped
to the windshield
Fuel Pump may be worn out
Suzuki sv 650 oil filter seal blew out loosing oil. fitted new filter and new oil seal blew again after a few minutes???
there should be a oil pressure sending unit close to the filter, install a manual guage to check the actual pressure, and chack the filter mouting seal surface with a flat edge it may be warped
Top Dewalt Garden Experts
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
