I\'m assuming you have the 3.8 engine,although i believe the firing order is the same on all there v6 sideways mounted front wheel drive Windstars. That firing order is 1-4-2-5-3-6, with 1-2-3 going from left to right on the back side of the engine and 4-5-6 left to right on the front side of the engine.Looking straight down at the coil from the front of the car,you\'ll see 2 rows of coil terminals.The row on the right side is 1-2-3 going from top to bottom,row on left side is 6-5-4 going from top to bottom. Hook the number 1 coil terminal to the number 1 spark plug ,being careful to use the spark plug wire that is closest in length to the length you need. If your just replacing wires,yuo shouldn\'t have to much trouble. If your nreplacing the spark plugs you will find the ones in the rear,especially the number 2 [the middle one} are pretty difficult without removing the cowling. A total pain brought to you by the designers at Ford!
SOURCE: i lost the wiring diagram for the 2003 ford windstar spark plugs
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Brown/White
Left Rear Speaker Negative Wire (-): Light Brown/Yellow
Right Rear Speaker Positive Wire (+): Light Brown/Green
Right Rear Speaker Negative Wire (-): Brown/Pink
SOURCE: i think the spark plug wires may be mied up on my
2000 Ford Windstar 3.0 liter V-6 VIN "U"
2000 Ford Windstar 3.8 liter V-6 VIN "4"
Hope this help.
SOURCE: Need wiring diagram for 2003 ford windstar radio
We don't have wiring diagrams available due to copyrighting. You can access the factory wiring diagrams here.
