'Unbalanced Load' occurs when the machine detects that one side of the tub is heavier than the other.
This most often happens when heavy and/or large items become pushed to one side of the tub during the wash and become much heavier when the spin cycle engages.
This is more often seen in 'tub' style machines rather than front loaders.
Usually the machine has a safety system which shuts down the spin cycle and 'buzzes' to alert you to reach in and move things around in order to rebalance the load.
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
