Konica Minolta magicolor 2400 Laser Printer Logo
a
ali m Posted on Jun 04, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Service call:14H on Konica Minolta magicolor - Konica Minolta magicolor 2400 Laser Printer
Hans-Goran Branzell
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 10, 2024
Hans-Goran Branzell
Contributor
Level 1:
Answers
Questions
Helped
1460
Points
I have a Konica Minolta Magicolor 2300. A service manual for this machine is easy to find:
https://www.manualslib.com/manual/90069/Konica-Minolta-2300.html
The procedure to remedy error 14H is described on page 163, but an important point is missing.
Go to page 62 in the manual. To the left in the upper drawing there is a double cog wheel the axis of which is denoted by a dotted line. Inside this wheel assembly is a helical spring that acts as a coupling. After many years this coupling gets too slippery and loses the grip. This is what the spring looks like:
https://www.precisionroller.com/springs-for-konica-minolta-bizhub-162/details_42971.html
Put a piece of sandpaper on a stick. While holding the spring against a flat surface roughen the inner surface by sanding it axially. The result will not be visible to the ***** eye but it will help There are two cylinders inside the spring. One of them is fixed to the spring. The other cylinder can also do well with the same treatment.
Important: Before assembly clean the parts with break cleaner or similar fluid.
There is another thing that I had to fix long ago. I do not remember the error code but I can describe what I did. In the printer there are several solenoids that are used for synchronization of the internal movements. In fact, there are three solenoids in the wheel train that I discuss above.
These solenoids used to have a foam based cushion against which the actuator arm rested when the solenoid was idle. This cushion had turned into a sticky goo that prevented the arm to move. It was not sufficient to remove the goo because residual magnetism could serve as a sticky goo instead. My solution was to make strips of aluminium sheet, around 1 mm thick. These I folded around the part I installed the strips on. I also added some glue on the backside where it made no harm.
May you printer be with you for years to come!
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Dec 28, 2015
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910558
Points
11959
Transfer separation Roller open the machine where the transfer belt is see a sponge looking roller on the other side ensure it is properly installed or replace it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • 16 Answers
  • Posted on Jul 19, 2008
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Dan Hudson
  • 119 Answers
  • Posted on Nov 18, 2008
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
Anonymous
  • 44 Answers
  • Posted on Apr 20, 2009
SOURCE: konica Minolta magicolor 2430DLshowing Fatal o8h
Error 08 relates to the main motor having problems turning. Quite often this is caused by a faulty consumable (opc,toner or transfer belt). Could also be that the lid is not closing properly and stopping the toner carousel turning freely.
Anonymous
  • Posted on Mar 08, 2010
SOURCE: Konica Minolta Magicolor 4690MF gives 0502 error.
machine trouble 0092 service call
This happen after I cleaned the waste box for Konica Minolta Magicolor 1600W
Anonymous
  • Posted on May 11, 2010
SOURCE: how do i fix the error message MACHINE TROUBLE
1. Main switch is tuned ON.
2. Press the following keys in this order
2 -> 6 -> 2 -> 7 ->3
3. Main switch is tuned OFF/ON
1helpful
Magicolor 2300dldl fatal error code 14h
The second transfer roller might be missing. Is not properly installed. If you open the printer you will see a roller made of sponge like material. That is the second transfer roller. Replace it if above does not work also ensure the transfer belt is properly installed. that is across from it in the machine.
Konica Minolta Magicolor II
WOW. now that is a LEGACY Minolta Machine, Konica Minolta web site does not even list that machine try this site for a service manual
Service manuals electronic components datasheets and equipment schematics...
1helpful
Do you know the service password for a konica minolta magicolor 2350
hi........
Konica minolta magicolor 2350 service password is not available.......
pls contact to the customer care..........
thank you.............
1helpful
I have fetal error code 08H,14H &15H in KONICA MINOLTA Magicolor 2430DL. pl help to resolve the problem
 When fatal error codes are displayed call tech support at Konica Minolta:
http://kmbs.konicaminolta.us/content/salesservicelocator/findservice/findservice.html
FATAL ERRORCODE:XX
An error has been detected with the item indicated "XX" in the service message.
Reboot the printer. This often clears the service message, and printer operation can resume.
If the problem persists, contact Technical Support
1helpful
Fatal Error 14h 2300 DL
printer.konicaminolta.com/service/ASP/mc2300/.../mc2300SM.pdf
this link is going to take you the manuel that what you have to do when you got an error.
12helpful
2answers
2answers
Printer driver
You can go to the konica web site, under service, software, and simply download what you need, instructions for use are slef explanatory
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
