Know my battery needs to be replaced. charging off power source, says I have 59% available. should I remove the battery?
SOURCE: ReplaceToshiba Satellite Pro 6100 laptop CMOS battery
the cmos batt is located near the cpu, is a quarter look alike batt. disconect it fron the two cable connector to the mb and replac e with a new one.
SOURCE: Toshiba Satellite P30 (new) Battery (and old) not charging
1. You will need to check the power adapter it may have lost it's ability to send a charge to the board.
2. Also the connector to the PC may be damaged and the solder joint at the mother board may have cracked or damaged.
3. Check also that you have the battery completely snapped in place.
4. check the contacts on the battery itself.
5. You PC may need service.
SOURCE: TOSHIBA SATELLITE M45-S165 won't charge Battery.
it could be possible that changing the dc jack at the back may fix the problem however it could be a faulty new battery as ive had a few copies (not original) which would work for a week or so then die or others which wouldnt work at all, i finaly splashed out on a new original battery and it hasnt let me down and i bought it over a year ago.
Hope this helps
Testimonial: "Thank you. I will contact the battery supplier."
SOURCE: I want to restore my factory settings on my toshiba satellite
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
