NorStar M7324 Telephone Logo
Posted on Nov 05, 2007
Norstar Phone System - How do I change the time?
Office in daylight savings time in need of help! This is what I can tell you, so I hope you can piece it together to help me...
I have 2 manuels in from of me: Norstar M7208 Telephone User Card & Modular DR5 Telephone Feture Card. However my phone is a M7324. It is the only phone in the office with the administrative features, and the capability to change the time, but I have nothing to tell me how to do this. Can you help?
With the sincerest Thanks!
Barbara
A
Anonymous
Press feature **time
enter the time.
Press Feature **date
enter the date
1helpful
4answers
Setting the date and time
After selecting 1, type in the date mm/dd/yy (it doesn't appear on the screen) then press hold/save. Then type in the time again it won't appear on the screen press hold/save. It will then return to the main screen with the correct time and date. Hope this helps.
NEED TO CHANGE TIME ON PHONE DUE TO DAYLIGHT SAVINGS PHONE IS T7316E
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
1helpful
I have a Norstar T7316E phone system. I need to
Depending on the type of voicemail you have It can be accomplished by calling in to the office and when the main greeting starts playing press **, the administrator mailbox number, the password and the pound key (the administrator password must be changed from 0000). Once in the mailbox press either 9 or 99 at this point you can re record the main greeting.
Change Time
THe older norstar systems you had to go into programming to change time and on the newer systems press feature * time on your phone and follow the prompts. On the older systems go in to programming press feature ** 266344 (config) then pswd 23646 (admin) on your key pad this gets you into programming press next until you get to change time. You need an overlay which can with your phone system manual. If need more info please ask agian hope this helps.
4answers
Norstar CallPilot 100: need to change the time within the system to reflect daylight savings time
the time change goes off the system time to change system time press feature **7463 enter the admin password then press change and enter new time
4helpful
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Time & Date
the console takes its time from the clock in the system .its the system time that is incorrect and needs modification in overlay 2.this can occur when moving from summer time to winter time and daylight savings not setup in your system.
Daylight savings time
I beleive there might be a firmware upgrade for the processor, but other than that there is nothing you can program to accomplish that.
2helpful
Change the time
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Changing the time on my phone
Here is a link to the support page at NEC regarding this year's DST time change: http://www.neccare.com/kb/S7YGL52
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
