The Lamp is located in the front of the set. Remove the front grill, then locate the lamp door cover, remove the 3 screws holding the cover and remove. the lamp is held in place with 3 screws loosen the screws then pull the lamp out by the handle. when replacing the new lamp do not use too much force when seating the new lamp this can cause damage to the lamp connector inside. your manual has these instructions on page 95 and 96.
Through the front of the TV. Remove the speaker grille (IT SNAPS OFF & ON) & there is a lamp cover with 3 screws holding it in place, near the left speaker.
That lamp part#: 915P020010 $49.00 TO $100.00
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-62525
