Dometic NDR 1062 Refrigerator Logo
A
Anonymous Posted on Jun 03, 2014
NDR 1062 Overvoltage
I connected to a bad electrical and had 240v to dometic ndr refrigerator. I no longer works on ac or dc. Will replacing the black box board solve the problem?
5 Related Answers
Anonymous
  • 531 Answers
  • Posted on Apr 02, 2009
SOURCE: Dometic refig ndr 1292 not cooling all the time
you may have a defrost problem
johnwilldo
  • 3 Answers
  • Posted on Apr 15, 2009
SOURCE: Dometic NDR 1062 Interior Light Assy Fasteners
I finally did a Google search for the NDR 1062 and found the Illustrated parts breakdown on PPLs web site. Also, received an email from a helpful reader of Fix-Ya Site with another site that had the parts manual.
Anonymous
  • 553 Answers
  • Posted on Nov 06, 2009
SOURCE: my dometic refrigerator is not freezing properly.
If the refrigerator is 38 degrees and the freezer 18 degrees , both are not normal.
Have you used any hard and pointed object to remove any frozen food or Ice before this happen?
Have you notice any oily part coming out in the freezer or at the back of the refigerator which will indicate that there was a leak?
there are few factors that may cause your refrigerator to be like that:
1. A possible leak along with the tubing that will cause to loose the refrigerant which make the refrigerator to produce ice.
2. lost Compression (Motor compressor) this happen eventually specially the refrigerator is more than 10 years old
the best way to find out is to call a technician and have them check it
Sea Breeze
John Tripp
  • 4656 Answers
  • Posted on May 17, 2010
SOURCE: Light will not go out on Dometic Referigerator ,
Tell you what I am going to do and that is because the model number you listed in your post may be missing something I am sending you to
Click Here=> GasRefrigeration.net and if you cannot find it there on their site you can call them in the morning, Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Anonymous
  • 3361 Answers
  • Posted on Jul 11, 2010
SOURCE: My Dometic NDR1062 only runs on gas, its set for auto and has 110
There is a control board and a step down transformer that may be at fault.
These should be located in the lower rear of the unit.
NDR 1062 Dometic Refrigerator
Not unless you unplug the thermistor from the circuit board and let it run for 24 hours. If it does not cool after that then your cooling unit is bad.
2answers
NDR 1292 - Was freezing/cooling on electric, but stopped freezingcooling, tried gas but doesn't freeze or cool
Since it does not work on either AC or gas - do you have DC to the unit? I have spent many hours troubleshooting a Dometic that turned out to be a corroded DC connection.
Not cooling on 120 V0lts
NDR 1062, cools with gas but will not switch over to Ac . If i turn off lp, check light comes on and doesn't cool
2answers
2helpful
Inside light switch to be replaced only by getting the product
I can get you a light switch, I may even have one in stock. Have replaced [email protected]
Top Dometic Refrigerators Experts
Jay Finke
Jay Finke
Virgil Watts
Mike Cairns
Mike Cairns
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
