Hyundai santafe 2004 how to fix p0456...or what are ur suggestions for repair? i was advised to change the gas cap!
Here's the procedure:
Purge Control Solenoid Valve (PCSV) Line Inspection
1. Ignition "OFF".
2. Disconnect the hose leading from the PCSV to the intake manifold at PCSV.
3. Using a vacuum pump, apply specified vacuum(Approx. 15 in, Hg) to the manifold side of the valve and verify PCSV holds vacuum.
4. Ignition "ON" & Engine "OFF".
5. Install scantool and select "EVAP PURGE VALVE" on the Actuation Test mode.
6. Activates "EVAP PURGE VALVE" by pressing "STRT(F1)" key.
7. Verify PCSV release vacuum while valve is activating(should hear a faint click from PCSV).
8. Repeat this procedure 4 or 5 times to ensure PCSV reliability.
9. Is PCSV working properly?
YES
? Go to "Canister Closing Valve(CCV) Line Inspection" procedure.
NO
? Verify arrow on PCSV is pointing towards intake manifold. If it is not, reverse installation. Reinstall as necessary.
? If OK, check for cracks or damage in hose connecting PCSV and intake manifold. Repair or replace as necessary.
? If OK, test with a new PCSV and check for proper operation. If problem is corrected, replace PCSV and go to "Verification of Vehicle Repair" procedure.
1. Return vehicle to original condition.
2. Ignition "OFF".
3. Disconnect the hose connecting Canister Closing Valve(CCV) to canister.
4. Blow air to the canister side of the valve and verify air escapes to the air filter side.
5. Turn ignition on and jumper a wire to GND(back probe) at terminal 2 of the ECM connector(CCV valve should click).
6. Blow air into hose and verify air does not escape.
7. Repeat this procedure 4 or 5 times to ensure CCV reliability.
8. Is CCV working properly?
YES
? Go to "Fuel Tank Pressure Sensor Inspection" procedure.
NO
? Check for cracks or damage in hose connecting CCV and canister. Repair or replace as necessary.
? If OK, replace CCV. If CCV was stuck closed, inspect all lines and canister for liquid fuel. Replace any contaminated components and blow out lines and go to "Verification of Vehicle Repair" procedure.
1. Start engine and install scan tool.
2. Monitor "FUEL TANK PRESSURE" parameter on the current data list with depressing increasing engine speed.
Specification : Signal value will vary between -2mmHg to 2 mmHg depending on variation in engine speed.
A. Approx. 0~2 mmHg(2.5V) at Ig. On
B. Approx. 0 mmHg at 1400rpm .
C. Approx. -2 mmHg at 4000rpm.
3. Is signal value within specification?
YES
? Go to "PCSV to Canister Line Inspection" procedure.
NO
? Check for cracks or damage in hose connecting canister and fuel pump. Repair or replace as necessary.
? Check for open or short in FTPS harness. Repair as necessary.
If OK, test with a new FTPS and check for proper operation. If problem is corrected, replace FTPS and go to "Verification of Vehicle Repair" procedure.
1. Check for leakage in hose.
(1) Disconnect the hose leading from the canister to the PCSV at canister.
(2) Using a vacuum pump, apply specified vacuum[Approx. 10cmHg(4 inHg)] to the manifold side of the valve and verify PCSV holds vacuum.
(3) Monitor vacuum pressure for 1 minute. After 1 minute, pressure should not drop more than 2cmHg(0.8 inHg).
(4) Is pressure within specification?
YES
? Go to "2. Check for leakage in canister" procedure.
NO
? Check for cracks or damage in hose connecting PCSV and canister. Repair or replace as necessary and go to "Verification of Vehicle Repair" procedure.
2. Check for leakage in canister.
Thoroughly check all fuel vapor hoses and hose clamps between:
1. Canister and fuel tank.
2. Canister and CCV.
3. Canister and PCSV.
If NG, replace hose or clamps as necessary and go to "Verification of Vehicle Repair" procedure.
If OK, go to next step as below.
(1) Disconnect hose clamps and remove canister assembly .
(2) Block the hose of between:
A. Canister and fuel filler neck.
B. Canister and CCV.
C. Canister and PCSV.
(3) Apply maximum of 10cmHg(4 inHg) pressure through fuel tank port from canister.
(4) With system sealed and pressurized, check for leaks.
(5) Were any leak(s) found?
YES
? Repair or replace leaking system component(s) and go to "Verification of Vehicle Repair" procedure.
NO
? Go to "Fuel Tank Line Inspection" procedure.
1. Relieve the fuel system pressure and remove the fuel tank.
Before removing the fuel tank, make sure the fuel hoses are not leaking.
2. Block all of the following outlets:
(1) Fuel lines.
(2) Fuel filler neck.
3. Apply maximum of 10cmHg(4 inHg) pressure to the EVAP. hose at the fuel tank. Then, pinch the EVAP. hose to retain the pressure.
4. Check the suspect area for leaks with a soap solution.
5. Were any leak(s) found?
YES
NO
? Check for poor connection between ECM and component: backed out terminal, improper mating, broken locks or poor terminal to wire connection. Repair as necessary and go to "Verification of Vehicle Repair" procedure.
