Medical Logo
m
mike Posted on Jun 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Eagle problems 1988 eagle bus motorhome v6 Detroit dies when at stop sign if it does not stall it will not take throttle if u turn it off then start it right back up its fine till next time u come to idle no matter 1/2 mile or 1000 miles someone please help
Les Davis
Level 2:
Sergeant:
  • Expert 247 Answers
  • Posted on Jun 05, 2014
Les Davis
Expert
Level 2:
Sergeant:
Answers
247
Questions
Helped
36568
Points
622
Sounds like your idle is too low. Adjust the idol on your carb or fuel injection.
2helpful
3answers
Why is My 1988 GMC S15 Randomly dying?
Possible IAC, idle control valve, trouble. Could be dirty. Did you add the sea foam through the throttle body or fuel tank? Also could be the electric control module.
1988 mercedes benz 300 e starting problem
Crank position sensor when this sensor fails the fuel pump will not turn on,and yes it stall out anywhere,and when it cools off it allows you to start up easily,it is located on the crankcase,above the starter
I have a 1991 talon eagle turns over when the gas is to the floor and wont say idling also when driving and coming to a stop it dies whats wrong
you could have a high fuel pressure problem and when holding the throttle all the way to the floor you put the system in flood mode which shuts off the injectors to burn off excess fuel in the engine.and when you release the throttle the system returns to normal.when driving you could be using the fuel that is being over supplied at the speed your driving.also the egr valve could be stuck open causing the engine to stall at idle.something to check out.
My 1988 chrysler new yorker dies when its hot and when i try to start it again its like it isnt getting any fuel
try cleaning the throttle body if they get even a little dirty they will stall,be hard to start,idle iradically [idle dips at a stop then goes up]
1helpful
2answers
2000 elentra- stalling at the stop light
First suspicion - TPS (Throttle Position Sensor)
2helpful
2answers
1988 oldsmobile cutlass ciera check engine light on then stalled.
Wow! thats verry low miles for an 88. Check the fuel pressure at the injector. If the pressure is low the filter could be clogged or the pump is not putting out enough pressure. Replace both if the pressure is not up to par. also check the fuel relays.
Top Medical Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Are you a Medical Expert? Answer questions, earn points and help others
