Question about Spy Vehicle Parts & Accessories
Car door not opening
How to reset my alarm ,the door is not unlocking
    Top Expert:
  • Spy Master
  • 8,918 Answers
Hi there's this website something like reliable-store and it is very amazing for manual for repairing servicing anything
someone on fixya recommended it to me and I thank him even today
They have full manuals and it's verrrrry cheap and mine
I got free in offers
3rd time I also had an issue with the file so the girl replaced it in 30 mins
there is one more but i don't remember its name it was 2 years back bitman something link this
Try it out brother
Posted on Jan 31, 2019
SOURCE:
  • 20 Answers
SOURCE: alarm for audi A4
Try disarming the car from the trunk. Sounds like the door lock switch is not deactivating the alarm, which it should, with or without the remote.
Posted on Apr 25, 2009
  • 4 Answers
SOURCE: VW 2000 New Beetle door sensor/car alarm goes off when doors open.
I found a thread - http://forums.vwvortex.com/zerothread?id=1542461 that details the repair of the soldering on the key lock door module. Our 2000 new beetle had the same issue. Also sometimes it refused to start. Soldering pins fixed it all.
Also see http://forums.vwvortex.com/zerothread?id=1015107 for releasing window from track, And door handle from inner panel.
I ripped the door apart and re-solderd the pins. I only had one pin with cracked solder but two others looked thin so I did them while I was in there. It's about a four or five hour project if you have all the tools. (8mm triple square also called an 8mm internal was the hardest to find - Also needed Torx T8 T10 T15 and T30 plus Philips Screw Driver. )
Project is difficult but not too bad for the mechanically inclined. A 7 on a scale of 10.
Since re-soldering pins - no more issues! My guess is that a VW dealer would get $200 for a new moduel plus 5 hours of service time for this gig - easily a $500 to $1000 bill. My cost - several new tools - about $25.00.
Posted on Jun 22, 2009
  • 78 Answers
SOURCE: VW Beetle Alarm goes off for no apparent reason
the sensitivity on the alarm itself is too high, or there is something around the car that is interfering with the frequencies that are sent / received by the alarm itself, like other car alarms, power lines (mine actually did it when i parked under a power line) or the alarm unit itself is malfunctioning.
make sure that nothing is around to the (other cars with alarms) or look up under your dash, above your pedals (might have to take the trim plate off) and / or turn the sensitivity knob (flat-head screw driver, or just a simple protruding knob) down. make sure the battery in the remote is good too. if it stil ldoes it after this, then your remote needs to be reprogrammed.
Posted on Sep 24, 2009
  • 921 Answers
SOURCE: i need to reset my car alarm on my 02 vw golf. the
stick key in driver door lock and unlock it. If that works, now see if the remote will unlock the door or doors..i remember reading in an owners manual once where you can program which doors open and close by they way you press and hold down the two main buttons, also after a battery change in the remote, i think, but not sure, i did this on a blazar i once owned... the owners manual said, that you had to be within 20 feet and press and hold down both buttons till it makes the arming sound.... Can i get some feedback cause im curious..thanks.
Posted on Apr 04, 2010
  • 87 Answers
SOURCE: I have a 95 VW Jetta III that I just purchased.
Insert the key into the door lock on the driver side and move it to the unlock position two times quickly. That should turn off the alarm.
Posted on Dec 27, 2010
My alarm goes off intermittently
Try resetting the alarm, using the instructions given at the link below. I'll also copy the text here.
  1. Insert the ignition/door key in the door lock on the driver's- side door of your Mountaineer.
  2. Turn the key to the lock position.
  3. Turn your key to the unlock position.
  4. Turn your key to the lock position.
  5. Turn your key to the unlock position. Your alarm is now disabled. If your key fob works, you can also press the unlock or alarm-disable button on the fob.
  6. Start the Mountaineer's engine and allow the vehicle to run for at least 10 minutes. This will allow the alarm to relearn the default settings. You must make sure that you have disabled the alarm first, however, before you attempt to start the vehicle, so that the alarm will reset itself.
http://www.ehow.com/how_5978302_reset-mercury-mountaineer-alarm.html
If these instructions don't work, you can try resetting the car's computer by unplugging the battery for half an hour. However, that will reset the keyless entry code, as you can see in the fixya article I link to at the bottom
http://www.fixya.com/cars/t4755856-we_bought_it_used_and_we_dont_know_the_k
Jun 10, 2015 | 2003 Mercury Mountaineer
How to reset car alarm
if you mean the alarm is going off by accident when you opened a back door or trunk with the alarm set, you just have to put the key in the drivers door and unlock the door(s).
Dec 31, 2013 | 1994 Volkswagen Jetta
I have 98 Camry Le and the door locks lock automatically shortly after the doors are unlocked and the alarm will set also. What could be the problem? Alarm Control Box?
if you use the keyless entry to unlock the vehicle & don't open a door within 30 secs.the vehicle will automatically lock & the alarm will reset,if you unlock it with the key this shouldn't happen.....cheers.
Sep 01, 2011 | 1998 Toyota Camry
2003 Monte Carlo SS, FOBS won't unlock doors (new batterries), use key and open the door with the door open FOB will lock and unlock the door, shut the door and the FOB won't lock the doors. After...
If the passkey is messed up, there will be a light on the dash that says security, or have a picture of a car with a lock thru it. If there is no light when the key is turned forward, then its NOT a passkey problem.
Aug 17, 2011 | 2003 Chevrolet Monte Carlo
WHEN I PUSH TO BUTTON TO UNLOCK MY 2007 HYUNDAI VERACRUZ LIMITED, IT UNLOCKS OK BUT THEN WHEN I OPEN THE DOOR THE ALARM SOUNDS UNTIL I TURN THE IGNITION SWITCH. AFTER THAT, EVERYTHING OPERATES NORMALLY. ...
the car has two codes one is fixed the other is a rolling code which changes each time you press the unlock button,the first is allowing you to unlock the car but when you open the door it thinks your trying to steal it and the alarm goes off,then when you put in key it is recognising the key and switching off the alarm....NOW if you follow the instructions in the book you can reset the alarm(as i worked for hyundai over 5 years ago i cant remember the sequence,sorry)
Aug 21, 2010 | 2007 Hyundai Veracruz SE
I had my car window opened. I locked the door using my remote and went into my house for about 10 minutes. I came back out and unlocked the car door through the opened window. THe alarm went off. I stopped...
now you know what sets off the nissan alarm.lock the car,with the key, hold key over for 30secs then unlock with remote.should reset system....you unlocked the car manually so you need to lock the car manually....
Mar 05, 2010 | 2000 Nissan Maxima
Car sat for six months. Battery went dead and replaced with new one. Got it started after new battery, now it won't start, the alarm led is either flashing bright or very dim flashing fast. I'm sure that...
When alarm goes off,put key in ignition and turn,the alarm should go off and alarm should be reset.Or,remove positive battery cable,wait 10 minutes,reconnect,when you open door,alarm will sound,insert key in ignition and turn key and alarm should go off and alarm should be reset.
Aug 14, 2017 | 1994 Toyota 4Runner
Vehicle Parts & Accessories Logo
76 people viewed this question
Top Spy Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Norman Al-Anbar
Kardoc
Are you a Spy Vehicle Part and Accessory Expert? Answer questions, earn points and help others
