Question about Maytag MAH8700A Front Load Washer
Manual door release
MAH 3 door won't open? Does it have a manual release somewhere?
3 Suggested Answers
SOURCE:
SOURCE: Maytag MAH 3 Door will not unlock.
OK so the MAH3 Front load is what I assume you're talking about. I found this question looking around when I had the same problem.
So not able to find a soluton I just went to work with my screwdriver. To get the door open you do as follows:
1. Unplug the washer and wait for 5-10 minutes. Safety first.
2. At the back of the machine on the top left and right sides there are 2 screws (mine where black I dont know that they all will be) that hold the top plate in place. Remove them.
3. Once the screws are removed put your palms on the top of the washer and push the lid towards the back of the washer. The lid should slide back a bit then you should be able to lift it off. Put it aside for now.
4. You should now be able to see everything inside the washer. Look straight down from the top where the door is. On the right hand side of the door (this might be different if you have it setup to swing the other way) you will see wires leading to the electronic release for the door. The manual release you're looking for sits at the very BOTTOM of the electronic assembly. Snake your hand down past the wires and and the bottom of the black box thing there is a single "stick with a ball at the end" pull that DOWN while you pull the washer door open (maybe have a friend / wife help). You will not be able to see what you're doing at all but it seemed pretty easy once I figured it out.
My problem apparently (and I couldn't tell this with all the clothes inside) seems to be that the water didn't drain all the way? This appears to be while it wasn't releasing the door.
Anyway good luck!
Posted on Jan 22, 2009
Daniel S
  • 4323 Answers
SOURCE: The front door lock will
Hi
Please check the wax motor for proper resistance. To check the resistance, disconnect the electrical supply from the washer and remove the wire harness from the wax motor terminals and place ohm meter probes on it. The wax motor should have a resistance of approximately 1900 ohms at room temperature. The machine control monitors the door lock mechanism to ensure the door is locked. This is done through the door lock enable switch. During "lock mode," the shaft of the door lock mechanism is pressed forward by the door lock wax motor, and the shaft presses in the button of the door lock enable switch. If the machine control board sees the switch OPEN during the spin cycle, the machine control board will automatically shut the washer OFF. This is caused by a weak spring in the door lock wax motor. Replace the complete door lock mechanism. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 01, 2011
Where is the inside trunk release on a 2000 vw beetle. Trunk lid will not open with key, fob, or door release.
Trunk won open even with manual release http://newbeetle.org/forums/new-beetle-convertible/54170-trunk-wont-open-even-manual-release.html there is good info here C24OF
Dec 21, 2016 | 2000 Volkswagen Beetle
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on esupport.sony.com
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
2008 XC90/rear doors won't open from inside. Is there a switch? Or is there a problem?
Yes there is open doors a small switch should be below the door latch.if you can not find look in the owner manual
Dec 29, 2012 | 2008 Volvo XC90
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Door won't open
You will need to remove the top cover of the washer and reach down to release the door with the manual release.
Apr 25, 2012 | LG Washing Machines
The door is locked and won't open; how do i unlock it manually?
unplug it,remove the bottom panel,stick your hand up where the door lock assy. is and on the bottom of the door lock assy. there is a plastic wire that releases the door manually,grab it and pull down and the door will release.
Jul 10, 2011 | Kenmore Elite 45986 Front Load Washer
Wireless keypad won't accept our original code. Door won't open. When I enter the code the backlight on the keypad blinks rapidly. I need help. I have no other way to get in my...
Sounds like the receiver in your opener has quit working. Unless you break in you need to call a door technician. They can drill a hole in the door, use a special tool to pull the manual release and open the door. You should then have them install a keyed manual release if this ever happens again. They can also repair or replace your opener.
Jun 20, 2011 | Sears Craftsman LiftMaster Chamberlain...
Fuel tank release button doesnt work is there an emergency switch somewhere to open it?
I can't say I'm sure on this but almost all vehicles that have locking fuel doors have a release cable inside the trunk near where the door is located. May be behind the trunk liner material in that general area. If you have your owners manual it should have a description of the fuel door operation in it somewhere along with how to open it should the normal system fail. Good luck and hope this helps!
Jul 29, 2010 | 1999 Mazda Millenia
Anyway good luck!
Mar 18, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag MAH8700A Front Load Washer Logo
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
