Samsung st65 14 megapixel digital still camera with 5x optical zoom, 2.7" lcd Logo
A
Anonymous Posted on Jun 01, 2014
Samsung ST65 digital camera white screen but everything else works what is wrong?
The camera was not dropped or anything and everything is working fine except I cant see anything in the screen it is white and sometimes it will have a line going through it. What's wrong with it?
5 Related Answers
A
Anonymous
  • Posted on Oct 28, 2007
SOURCE: LCD Screen is White
The ribbon cable you require is here:
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=1228041&query=Samsung%20VPD351&model=VPD351&path=98821,112905:98830
Panso
  • 4 Answers
  • Posted on Jun 10, 2008
SOURCE: Samsung LE26R73BDX 26INCH - LOSS OF DIGITAL SERVICE
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Anonymous
  • 5 Answers
  • Posted on Oct 16, 2008
SOURCE: Samsung Digital Camcorder VP-D351
hi..Please to pass on the remedy..I had this two weeks ago.. lcd ribbon is brocken.. breaks over time with being opened and closed.. Part available form partmaster.co.uk.. part no..SAMAD9706489A.. lcd fpc ***. easy to replce ..take you time and try yourself.. if i can help with instructions [email protected].. cost of ribon £11.49.. GOOD LUCK STEF.
Anonymous
  • 11896 Answers
  • Posted on Apr 21, 2009
SOURCE: white screen on samsung sch-r450 messenger frm water damage
the only possible thing you could do yourself is to remove the screws, pull it apart and try to blow dry. That's the only thing you can personally do.
Anonymous
  • 56 Answers
  • Posted on Jun 30, 2009
SOURCE: my lcd won't display a picture
the connector between the LCD and internal parts of the camcorder is called RIBBON. based on what you said, you need to call Samsung hotline for repair of your camcorder
USB Cable won't connect
Possible bad cable. Possible bad plug on computer or camera. Possible XP simply isn't listening when you plug it in.
1helpful
My camera screen is white totally no colours no menus cant see anything just a plain white screen it dropped about 13 inches any help
Have you tried pullimg yhe memory chip ad batteries and reloading them. And if camera is that new it should still be under warranty take it back to where you purchased it, dont tell them you dropped it and they should help you or replace the camera.
My playback button ON Samsung camera doesn't work! :(
How wet is "a lil" wet? If the device was submerged in water it likely has severe water damage, you can try putting it in a bag of rice for 24 hours but if that doesn't fix anything there is nothing you can do other than buy a new one, or replace the parts that were damaged, and I do not recommend trying that if you have never done so before. Good Luck!
My ST500 samsung digital camra's touch screen is not working, but everything else does perfectly is there anything i can do to fix this? I don't understand why it doesn't work it has not been...
you have a bad camera. If your camera is still under warranty, I will repair it for 35.00. If it is out of warranty, then I will fix it for 165.00
call Continental Photo, 718-268-6440 Mon - Sat 10am - 6pm, ask for vic
Jul 31, 2011 • Cameras
On Samsung ST65 is there a self timer? I can't find any....
Yes, on the Samsung ST65 you can use the self-portrait feature.
On page 44 of the user manual you can find the explanation of how to use it.
Here you can find the manual:
http://downloadcenter.samsung.com/content/UM/201102/20110208153302382/ST65_ST67_English.pdf
Basically you can trigger the camera when faces are in center of picture, or when you smile of blink the eye.
Let me know if this helped you, bye
May 04, 2011 • Cameras
Dropped my camera,screen is white and wont display anything
Try and remove the batteries and wait then a few minutes, then reinsert them and see if that works.
Jan 16, 2010 • Cameras
Samsung s860 camera got dropped turns on but screen is only white
dropping the camera might have caused damage to your LCD screen, best advise I could give is to send it in for repair
check if you can still view old pictures or if the on screen displays are visible, it will narrow down if the problem is with the lens or the screen
hope this helps
I have dropped my SAMSUNG D1070 PINK digital camera. The screen is now white with a black mark inside it and appears to have a crack inside it...Can this be fixed?? I only got the camera at christmas....
Dear lauren_holt,
I'm so sorry to hear that your Pink Samsung D1070 Digital Camera was dropped and appears to be cracked and now has a screen that is white with a black mark!
This doesn't sound good!
Have you tried taking the battery out (make sure you leave it out for a least 1 minute) then replacing it (sometimes overnight or 24 hours will be required)?
Sometimes this works!
You may be covered under the warranty, unfortunately some companies might not honor the warranty if you dropped it.
I'm disappointed in Samsung for even making a camera that would break when dropped if this is true!
Anyway click on the following link for Samsung Support @ http://www.samsung.com/us/support/main/supportSupportMain.do
jackiaria
Tuesday 02-24-2009 5:41am EST (USA)
Feb 24, 2009 • Cameras
4helpful
3answers
My samsung digimax 503 has a white screen!
Oh my gosh this really works! Our screen went white, we hadn't dropped it or anything. The camera still worked fine but we just couldn't see what we were taking a picture of. We tried this solution and now we can see the picture through the screen perfectly. THANKS for posting this!
Top Samsung Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Samsung Car Audio and Video Expert? Answer questions, earn points and help others
