SOURCE: Have a Miele W320, during the rinse part of wash
Is the drawer gunged up? Are you using too much detergent?
Remove the drawer, and clean it with hot water and a brush.
Look into the empty drawer slot for any blockages and remove.
Replace drawer, try pouring hot water into the open drawer to try to dissolve and clear any blockages.
Consider using a dosing ball and adding detergent to the drum.
SOURCE: Miele 435-plus washing machine Problem: water
There's a hose or tube that goes from the dispenser cavity to the tub that is likely clogged. Small clothing can be siphoned into the hose or tube and block the water path causing it to leak out to the dispenser drawer. Locate the hose/tube port in the tub where the blockage may be located, if not, you have to remove the front panel fully access and take the hose/tube out for inspection.
Disconnect power then remove the screws attaching the top panel to the rear of the machine and slide it rearward and off. Remove the dispenser drawer then the screws securing the console to the machine cabinet. Lift the console off then remove the screws securing the front panel to the cabinet. Slightly lean the front panel forward and disconnect the door lock and switch assembly wire harness. Remove the front panel and set it it aside. The hose/tube can now be fully accessed for inspection. Reassemble the machine in reverse order of the disassembly steps.
Let
us know if you need further advice. Please accept
the solution should you find it helpful and informative. Accepting the
solution will not stop you from communicating with the expert. You can
still communicate with the expert as long as you need further advice
regarding the issue stated herein.
