You will need to check the drainage fitting these toilets are draining into. If it is a cross tee fitting without a baffle you are getting throw over across the fitting and it will not stop. The only fix for this is to replace the fitting in your drainage system. In Illinois it is a code violation to put this type of fitting in that application.
When these power flush toilets come out it made this problem worse. In short there is no fix for this problem other than redoing the drainage system.
