Appears on one side then both sides after a while. The tv looks brand new
SOURCE: Vertival Color Lines
I have the same thing on mine and it is just outside where the transition from HD to non HD is. I went back to the place that I purchased it from last year and as soon as I said I had a line in it he told me Toshiba will call me and they are replacing these tv's!
SOURCE: Vertical red line on Toshiba REGZA 52HL167 tv.
I have this same problem with my 52 inch toshiba regza , The repair shop has said the cost of repair is as much as it is to replace the TV. I am past the one year warranty, but less than 2 year ownership, so Toshiba won't fix the known issue. Solution is don't buy a Toshiba
SOURCE: vertical line
Typical repair bill for LCD TV flat panel repair is $200~300 range.
It sounds like the porblem with failed T-C0N board.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
SOURCE: i AM EXPERIENCEING VERTICAL LINES ON THE tv THAT
If I understand this correctly, you see vertical lines on the right side that show video content from the left side. This is caused by a failure in the video memory addressing. Unless a dying power supply capacitor is causing the digital logic to misbehave, the main board probably needs one of the following replaced: video processor, video memory controller, or one of the video memory chips. It might also be a vertical line address decoder on the LCD panel driver board. The blurriness might be caused by fault currents in the bad chip.
First check the power supply with an oscilloscope to make sure it's clean. Anybody who knows how to use an oscilloscope without getting killed by probing in the wrong place should be able to do this.
It's probably easiest to swap the main board for a refurbished one. If you want to do it yourself, first do some research on anti-static protection so you don't damage the new board with static electricity. You don't want to do more damage to the old board either; that will reduce its core charge credit value. If you need a how-to guide on this, post a request for it.
Bottom line: the set needs repair, but it is repairable. Best case is a bad capacitor in the power supply. These range in price from $0.30 to $3.00 plus shipping and handling. Worst case is a new main board or LCD panel driver board (probably $130-$300). Labor for the power supply or main board cases should be no more than two hours, probably more like one. A panel driver fault may be considerably more expensive; it is often necessary to almost completely disassemble the set to get at it.
SOURCE: i have vertical lines in right side of my 52"
I have the same TV and same problem. Here is contact infor for a class action lawsuit
Andy Edwards
> [email protected]
